Help, Bike won't start after bar install
Ok, I put on new bars on my 09 Streetglide following advise from many of the threads found here. I extended the throttle cable, ran wires internally, put the bike back together. Bike started fine, but got a few error codes that pointed to the TBW connection. Took the TBW back out of the bars and bypassed the green connector by hard wiring the internal connections. Everything "back together" and no error codes, but bike won't turn over. I've checked all obvious connections. Anyone have ideas of what I can or should check?
I have power, everything seems to work as expected. Bars lock just fine. I will check all connections and for pinched wires. Would a bad connection, effecting starting, throw a code? It's almost like it's a safety thing, like not starting because kickstand down in first, but I'm trying to start in neutral.
Since it started before I took the TBW back out and hardwired to get rid of the green connector, I figured I would start there. Maybe I soldered the wrong wires, or wires were damaged?? Nope. All looks as it should:
From yellow sleeve: red to brown, white to blue, black to black
From black sleeve: red to red, white to purple, black to grey
I left the TBW out of bars and connected up to try and start, still no luck. Wonder if I messed up the TBW sensor some how???
After further research, looks like there are a few different model TBW assemblies out there. I called the dealership, and found that mine is model number 32305-8. Referenced that back to some threads here and found it to be the exact opposite of what I did, this appears to be how I should have wired:
Black sleeve
Red - brown-pin 6
White - blue- pin 5
Black - black- pin 4
Yellow sleeve
Red - red- pin 3
White - purple- pin 2
Black - gray- pin 1
Glad I had a home office day today! Been banging my head against a wall. Going to go out at lunch to confirm.
Black sleeve
Red - brown-pin 6
White - blue- pin 5
Yellow sleeve
Red - red- pin 3
Black - gray- pin 1
