Indexing spark plug washer sizing....
Thanks for the input everyone...going to index regardless, just makes sense pointing the plug in the right direction especially if the plug your using only has one grounding strap. I suppose if I were using a plug with four straps one or more would be pointing at the intake? But since I dont read much about those plugs being used much its best to keep it simple.....take care, Tucci
check out this site, they have them with a lot of info http://youroilshop.com/plugs.htm
Interesting, I've talked alot of professional maintenance technicians also, and most agree there is a benefit, even in a bone stock motor. Just because something doesn't yeild a 15% increase in HP or 10 ft/lbs torque, doesn't make it a waste of time and money, but I will agree to each his own!
I'm changing out the plugs on my 2012 street glide today so I figured I will see how close I can get without using any washers.
Just so I get it right.... Mark the plugs ground strap side (not the open side) and place the mark at 4-5 o clock on the rear cylinder and 7-8 o clock on the front?
I figure it can't hurt anything.
Thanks for the help!
