Someone has to know this answer to this SEPST question
I've gotten conflicting answers to this question...I have a 2012 FLHTK.
Can the SEPST do a save of stock map (before any changes are made) in event I wish to return to stock configuration (for whatever reason). If so...can the stock map be saved to a file that can be saved on Hard Drive or USB Stick.
If it can be saved...is there any reason why a dealer doing work would not want to save stock map and provide copy to client?
Confused! Steve
Confused! Steve
I don't think so.
the SEPST's cannot pull the map data off of the ECM (at least not that I'm aware of).
You start with a base map, that was either loaded with the software, or downloaded from the 'net using the software...(one of these maps MAY be the same as a stock map)
Make changes to that map - these can be saved at any point. You then load a tweaked map into the ECM, and use your saved copy for future tweaks....
I do not believe that your dealer is correct. once the ecm is reflased the reflash replaces the original calibration. I believe that a dealer can reflash the stock cal using the dt.
I have both the sespt and tts and initially reflashed my stock ecm (2011 bike) with the stage 1 download before I got the tts and know my saved cal for the tts is the se stage 1.
Confused! Steve
Confused! Steve
Other Devices: downloaded map missing from my VH FP3
JZFloatingkent
The Dyno Room
05-16-2017 01:50 AM
triglide1
24
06-21-2010 06:07 AM
