Fairing Cap Rocker Switches
Old 04-16-2012 | 11:23 PM
bdjhog's Avatar
bdjhog
Default Fairing Cap Rocker Switches
Does anybody know who manufactures the oval rocker switches in the fairing caps? I'm looking for a momentary switch to use with my air compressor that will fit into one of the blanks and I am having a hell of a time finding one that looks like the HD ones. Thanks
Old 04-16-2012 | 11:26 PM
hog-doc's Avatar
hog-doc
Screamin Eagles use a dual switch for spot/cruise, its a push on push off that could be wired for up/down function!
Old 04-16-2012 | 11:28 PM
piesik650's Avatar
piesik650
kury makes one that's a duel rocker. looks good and works like a toggle.
CHILLLS's Avatar
CHILLLS
subscribed...want to know too & if you need to have something under the panel.
Old 04-16-2012 | 11:35 PM
White Ice's Avatar
White Ice
I believe H-D part #71764-07 is a momentary switch. It's the electronic lock-unlock switch for CVO tourpaks. I've read about guys using it for the 'garage door opener' mod.
Old 04-16-2012 | 11:43 PM
hog-doc's Avatar
hog-doc
Forgot about that one, thats the ticket!
Old 04-17-2012 | 01:33 AM
bdjhog's Avatar
bdjhog
Perhaps I should clarify how I intend to use this. I need to be able to power one thing, the air compressor, from one "on" position and then power the solenoid release valve from the other "on" position. So what I need is a on-off-on double throw momentary switch. Will the Screaming Eagle switch you mention function in that capacity or is only an momentary on-off switch?
Old 04-17-2012 | 04:44 AM
electradad's Avatar
electradad
The one they are referring to is a momentary on. You need one like the speaker selector switch used on the ultras. Its is an DPDT type switch. I think that is probably about as close as you are going to find
Old 04-17-2012 | 05:08 AM
ripper43's Avatar
ripper43
I looked for a year and never found one that would work. Good Luck.
Old 04-18-2013 | 09:02 PM
iglideUC's Avatar
iglideUC
I am looking to rid the switches of the red and green idiot lights. does anyone know or have knowledge of some covers or switches that do not allow the led to show through?
Quick Reply: Fairing Cap Rocker Switches
