Ceramic pipes, worth it?
No cons that I'm aware of other than the extra money. Ceramic pipes will in theory provide a bit more heat protection and as a result will in theory provide slightly better exhaust scavenging which in theory will result in better performance, but I personally doubt you'd notice any difference.
I went with Fullsac X-Pipe (which are coated on the outside only), because they were available and they allow you to keep the stock heat shields. Fuelmoto's 2-1-2 is coated on the interior and the exterior and also allow you to keep the stock shields, but there's nearly a three month wait, and I heard good feedback on the Fullsac product so I went with it.
I put a Rush Reaper ceramic coated pipe on my bike and noticed a big difference in heat. Much less heat! And all those rice crispie noises are gone when you shut down. I would recommend them. Putting a set on a friends 2012 RGC this weekend so we will see how much of a heat reduction there is as his bike is a real heat monster!!
I am debating between the full sac and the fuelmoto, ultimately it will probably come down to which one is cheaper for me since they both provide a ceramic coated cat less pipe that will fit stock heat shields. I definitely need the heat reduction. Sometimes my right leg feels like it's on fire when in traffic.
Guest
Posts: n/a
I have the Rush Ceramic Coated True Duals (Coated inside and out) and I HIGHLY recommend them. Come complete with new beautifully finished heat shields, Fit excellent, and look great. After shutting down I can almost lay my hand on the heat shields near the motor and not get burned. I can't see myself paying for a non-ceramic coated pipe (I've had coated headers in cars and other vehicles over the years).
we put the RUSH crossover system on the wife's FB and it is a tremendous drop in temp under her leg
there's no way to say if it's worth the money though until you see what the money is
if a fully ceramic (inside and outside coating) RUSH system, true duals is a $1000 and a non-ceramic of some other brand is $800 - then yes its totally worth it
if the system with ceramic is $1500 and the other is $800 then maybe not worth double as you will see some drop in temps just by removing the cat
for $200-300 difference I would say it's worth it all day long and 3 times that on a really hot day sitting in traffic
