Redline 20w50 oil package
Ive read alot about redline oil in transmission on the forum here and was wondering if anyone is running it in all three holes. Theres a complete 20w50 package on their website for 94.50. I think the regular dealership oil change costs around that much so Im wondering if the redline is that much better than harley synthetic. Is there an oil comaprison chart?
One reason Im considering redline in trans is to help reduce the hard clunking noise when shifting.
Thanks in advance.
Thanks in advance.
http://www.directharleyparts.com/che..._970_1457.html
No way you're getting a premium synthetic at the dealer, including the change and labor, for $85.
I run the same kit in both bikes. Worth the money IMO.
Just to help...
20W50 goes in the engine. You could run it in all three holes if you want.
Heavy Shock Proof goes in the transmission. Do not put this in your engine or primary!
Primary Chain Case Oil or MTL goes in the primary. Do not put this in your engine or transmission.
The Redline Heavy Shock Proof transmission oil is wonderful and solves the transmission clunk while making neutral easier to find. I've had it in all my harleys. The 20W50 engine oil is very as good; however I run Mobil 1 engine oil due to availability. Mobil 1 is available everywhere, I typically have to order the Redline. The MTL primary oil is also good if you are under 100HP. The MTL is too slippery for high HP applications and most of those guys (including me) have to switch back to dino-oil to make their stock clutch work well.
The Redline products are far superior to the HD synthetic oils. The HD oils are expensive only because they say HD on them. Personally, I see little value in the HD oils. They are certainly overpriced.
Good luck.
Good luck.
Oil does not fix the clunk. If it does you have way too thick oil and you are tearing up the small needle bearing. The clunk is normal. It's the square drive dogs that drop in the side of the gears, not the gear teeth. Also caused somewhat by fluid drag between clutch plates. All normal. If you hold in clutch when cold and goose it 3-4 times up to 2K and let it drop back it will free them somewhat and will 20-30% of the time eleminate it but its really is not hurting anything. Do not put too thick oil in to make it go away. if you do you will be posting shortly the inner needle bearings are bad on the transmission output shaft.
Is the Mobil 1 a synthetic lube? I like the fact of the availability factor. If Im ever on a road trip and end up with a leak or burning oil I can get the same oil almost anywhere. What wold be the alternative to redline that would also be readily available in most areas for trans and primary? Thanks in advance.
Ive been using Redline products in all my vehicles for years, IMO good products. They are the only full synthetic oils that are "ester" based as far as I know.
In the Harleys Ive owned, Vtwin HD with Shock Proof in the trans, in the primary VTwin Primary Oil and in my engines 20-50 Redline for V Twin. You will save a little buying the "kit"
In my Infiniti the company recommends an '"ester" based oil and they sell the Nissan brand for more than I pay for Redline synthetic 5-30. the Redline quiets down the valve train in a high rpm import engine very well. And in my Road Glide seems to also help keep the noises down as well as a little lower temps.
Redline is also available at a lot of NAPA Stores and all Cycle Gear outlets or order direct from the company
If you were to go on a long trip and your bike burned a little just bring a qt with you
When my bike was in for the hyd cam tensioner upgrade, there was a Heritage on the lift next to mine with a bad tranny. I asked the mech what happened and it was the needle bearings and too thick of oil trying to quiet the clunk.
The mech pointed to his Electra sitting outside with 112,000 miles using HD dino oil and Formula+ since new and not one problem.
Dont sweat the clunk!! Its normal!! Tens of thousands, maybe hundreds of thousands of harleys spend their whole life on plain old HD 360 oil and formula+
Everyone is correct, it does not solve the "clunk". But.....I did get a smoother shift, and easier to find neutral. I just ordered the kit off Amazon with a link from another thread. It was $88 with free shipping. It came within a few days, very fast. I had to order an extra qt of primary oil because the kit only came with one and my '10 SG needed round 1.4 qt. But IMHO, it is great stuff!!
