Notices
Quick primary service question
Old 04-15-2012, 07:30 PM
slhanks4's Avatar
slhanks4
slhanks4 is offline
Default Quick primary service question
I am performing my first full service at 10,000 miles. This is the first time I have changed all 3 fluids. Can you fill the primary on the jiffy stand, or do you need to have it level on a lift?
I'm just wondering if 38 oz of oil will overflow the inspection cover opening if on the jiffy stand?
Thanks!
Old 04-15-2012, 07:34 PM
Stiggy's Avatar
Stiggy
Stiggy is offline
Received 5,765 Likes on 3,146 Posts
No, it will just come up to the ring at the bottom of the clutch basket. I use a piece of cardboard to funnel the oil into the case.
Old 04-15-2012, 07:36 PM
slhanks4's Avatar
slhanks4
slhanks4 is offline
I have the fancy little HD funnel that snaps onto the primary opening. Thanks for the quick response!
Old 04-15-2012, 07:40 PM
hog-doc's Avatar
hog-doc
hog-doc is offline
THe bike needs to be upright and level and fill to the bottom of the clutch spring!
Not on the jiffy stand!
Old 04-15-2012, 07:47 PM
slhanks4's Avatar
slhanks4
slhanks4 is offline
Two conflicting answers. Guess I'll jack it up, then - just to be safe.
Old 04-15-2012, 07:50 PM
hog-doc's Avatar
hog-doc
hog-doc is offline
Check a service manual, my answer is correct!
stevevfd's Avatar
stevevfd
stevevfd is offline
I put a jack under it just to get the bike level. Then just fill the oil till it just barely touches the bottom of the clutch pack. On my 2010 it's about 1 and 1/2 quarts or so.
Old 04-15-2012, 08:14 PM
1flhtk4me's Avatar
1flhtk4me
1flhtk4me is offline
Remove the cover to find out!
Old 04-15-2012, 08:35 PM
slhanks4's Avatar
slhanks4
slhanks4 is offline
I already drained the primary before I removed the cover.
Old 04-16-2012, 03:41 AM
Stiggy's Avatar
Stiggy
Stiggy is offline
I misspoke. Yes, the bike needs to be level so that the oil touches the bottom of the spring, but....
The question was if the primary can be filled with 38 oz on the side stand, and yes, it can. If you know how much to put in, you can do it on the side stand.
Quick Reply: Quick primary service question
