Installing Grips on TBW
Old 04-15-2012, 01:58 PM
mike_oh's Avatar
mike_oh
mike_oh is offline
Default Installing Grips on TBW
Going to be helping a friend put some after market grips on his 2012 RGC. I have never installed grips on a TBW and looking for a few pointers on how it's done. Thanks!!
Old 04-15-2012, 02:14 PM
7Sixpack7's Avatar
7Sixpack7
7Sixpack7 is offline
Throttle side grip: remove two screws and split the switch housing and slide grip off. Slide the new grip on and spin it until you feel it set into the notch of the TBW sensor. Same for clutch side with the exception of "slide grip off". This side is glued on. Grab and twist HARD with the switch housing off. It will come off. If you don't want to save it just cut it lengthwise with a razor knife and peel it off.
Note: if there is a pattern to the grips put the TBW grip on first and line up the pattern on the clutch side with the throttle side (i.e. flame pattern).
Old 04-15-2012, 02:21 PM
TWIN CAM 96's Avatar
TWIN CAM 96
TWIN CAM 96 is offline
Don't forget to put your cardboard spacer in your front brake lever before you start on the right side!
Old 04-15-2012, 02:28 PM
mike_oh's Avatar
mike_oh
mike_oh is offline
Awesome! Thanks everyone!! He has the service manual but I won't see it until he comes over next weekend. Sounds like the throttle side is easier than cables!
Old 04-15-2012, 02:36 PM
Gunnysgt's Avatar
Gunnysgt
Gunnysgt is offline
There is a good chance you will need to loosen and move the master cylinder bracket on the throttle side a bit. The grip pulls out much easier if you do.
Old 04-15-2012, 04:20 PM
AOAVMC Slinky's Avatar
AOAVMC Slinky
AOAVMC Slinky is offline
Can you give some more details on this I am about to do this and haven't heard of this.
Old 04-15-2012, 04:26 PM
Deremetis0504's Avatar
Deremetis0504
Deremetis0504 is offline
5th Gear
i just used youtube to put on my iso grips simple and easy took less than 30 minutes
Romingnometx's Avatar
Romingnometx
Romingnometx is offline
Put the spacer between the brake lever and perch to keep it slightly pulled, or it can break the brake light switch in the switch housing when you reassymble the housing. It should be covered in the manual and instructions with the grips. My nostalgic grips came with a spacer.
Old 04-15-2012, 05:00 PM
Pastor John's Avatar
Pastor John
Pastor John is offline
Actually, I think you want to mount the clutch side first since it only goes on one way. Then mount the throttle side since the splines on the TBW allow you to match the orientation of the clutch side.
Old 04-15-2012, 09:01 PM
7Sixpack7's Avatar
7Sixpack7
The clutch side is glued on so it can be spun to any orientation you may want. How does it only go on one way?
On edit: I should add that my grips were Kury's and the clutch side did not have just one way to go one. Other brands/types may vary.
Quick Reply: Installing Grips on TBW
