K&N Air Filters
K&N Air Filters
Is there any benefit to replacing the stock air filter with a K&N replacement filter? Not talking about big sucker or screaming eagle type hi flow air cleaner.
I know the HD filter is supposedly washable, but for 11.00 or so, it's just easier to replace. I see the HD-1499 can be bought for around 35.00 or so on ebay and is washable,etc.
Just wonder if it allows more air in than the stock one does.
Joe
Joe
According K&N,it does offer more air flow when dirty.
Depending on how much you ride,the K&N would pay for it's self.
I have a K&N filter on my 2001 Dodge truck.That was the last filter I had to by for it.
Joe
Joe
Joe, does your bike still have stock air cleaner and pipes? If so, how many miles have you put on it and what year is it? Have you been "happy" with it remaining stock? I just bought a new 2012 Ultra Limited and the dealer "threw in" a lifetime maintenance plan with it, so I will just let them deal with the air filter.
Joe
In this particular instance, your air flow will be limited by the stock (restrictive) air filter housing itself. You'll not gain any airflow over stock with just the filter change. As stated above, you will gain a filter that will last longer than you'll probably own the bike. Some guys like the stock look and will change to a higher flowing filter then modify the stock housing to flow more air. Usually by drilling a series of holes in the backing plate or along the bottom of the filter housing where it doesn't show.
As far as increasing the air flow to mke it run cooler....the only way that will happen is if you increase the airflow across the engine itself. Increasing the air flow into or out of the engine will make it run leaner which in turn will make it run hotter. You'll need some type of tuner to increase the amount of fuel the engine recieves in order to accomplish your goal.
I thought it was a great deal. I am sure they are betting that I will not put many miles on the bike or keep it for very long. I plan to put at least 100,000 miles on this bike at the rate of around 15k-20k a year so I should easily get "my money's worth" out of the deal!!
