Should you replace a working Stator before it goes out??
So my buddy has a 05 Ultra with 50k on it and the stator just went out, the wrench said they tend to go at around 50k-ish. I have 70k on my 07 RG and would hate to have it go out while on a road trip, not only will it put a major damper on the trip but I would be stuck paying the stealer to fix it. What has been the experience on the forum regarding this, I would prefer to change out a stator that may only last a few more thousand miles than have it go out on the road. Your Thoughts
The new one might last 50 miles. How would you feel about that? New electronics are just as prone to failure as used. One, & I'm only talking about one, of the common failures in stators is the leads from the windings to the plug in the case chafing against the case. The insulator wears off & the stator grounds. If you want to be real pro-active pull the stator & fill the access to the plug with RTV with the leads isolated in the center.
Of course the easy way to handle it is to have a good tow service & get it fixed when it happens.........somewhere between 50 & 1,000,000 miles........<shrug>
Where does it end? I wouldn’t necessarily look at it like a battery that should be replaced every so many years, like out here. I’m thinking you could start replacing a lot of crap on your bike before it goes bad, primary, trans, whatever... In the end it’s a piece of mind but can get expensive. I guess this is why a lot of folks trade up every couple of years, don’t need to worry about any of it…
