Vance & Hines Fuel pak mods
OK Just for the record for people curious about the Vance & Hines Mods. Well this is what I did. I own a 2012 street glide with a 103 engine. I put these mods in one at a time.
Mod 1 Rhinehart 4" slip on exhaust..... Better sound, not much improvement in performance
Mod 2 Vance & Hines throttle Pak......Little better snap of the line, not too much improvement
Mod 3 Arlen Ness Big Sucker intake using the stock intake cover.....Huge power gain!
Mod 4 Vance & Hines Fuel Pak......Better sound, better perfomance and once dialed in from me calling Vance and Hines three times, it sounds great and has awesome mid range!
Conclusion, I think adding all of these together was the key. I have the mode settings I got from Vance & Hines, if anyone is interested. Great stage one improvement, and engine sounds awesome now!
the key to the OP, is that until the air cleaner was changed, there was little additional air flow into the motor ( which allows the revs to climb faster. fuel is added in proportion to the increased air).
motor mods are best done as part of a system - similar results would be found by using a high flow air cleaner ( such as the Ness) but retaining stock exhaust- again flow is restricted.
mike
mike
mike
mike
I looked last night and the Fuelpak site and mapping page is not particularlly up to date. To get 2011 info for FLHTK, you need to use 2010, but they are the same. Didn't look for 2012 info but they should make their site current though.
Stage One download
I also have a 2012 Street Glide and I'm looking at adding Vance and Hines headers and power duals. I was told that a stage one download woud not work and that I had to go with a fuel pack. Does that sound right? Also, any big difference between V/H and Rinehart other than price?
