Is this zerk fitting for grease ??
ORIGINAL: BigGeorge
Chances are if you only give 4 or 5 pumps on the grease gun the grease is not even getting to the bearings only being deposited into the neck. YeaI suppose after a number of years those 4 or 5 pumps will add up and eventually you will get grease to the bearings. Unless you see grease coming out, you have no way of knowing that the bearings are recieving any grease at all.............BG
Did you have to take anything apart to change the zerk fitting, or just remove the old one and screw in the new one? ? I was just looking at that last night when I was doing my 10000 mile maintenance. Where did you get the 90 degree fitting? Do you recall what thread size fitting? Do I ask too amny damn questions? Thank you.
caperss396
12-09-2006 11:59 AM
