2010 and up with non wideband 02's
2010 and up with non Wide-band 02's,
I have a question that everyone is asking all over the forum. Auto-Tune or no Auto-Tune? I own a 2010 SG and it has the 02's bungs that are not Wide-band compatible. Should I just tune around everything without header pipe that supports Wide-band 02's, or Put a 2009 V&H header-pipe on that supports Wideband and do an Auto-tune... Been looking at the Power Vision with or without Auto-Tune.....
Mods will be:
Mods will be:
- Header Pipes V&H with 2009 or 2010 ?
- CFR Racing 4.5" Fluted Mufflers
- Roland Turbine Air filter
- 103 kit and Cams in the next year or so..
No Harley has come stock with wideband O2 sensors, the 2010+ use a smaller sensor that was relocated to the collector.
If you're determined to use the V&H pipes and they don't have both sets of bungs, any muffler shop can weld them in. Just make sure the sensor protrudes into the exhaust flow. Get the auto tune with the Powervision. You'll have a setup you'll never outgrow, and one that'll let you do pretty much anything you want to the ECM.
