Cruise Control
Cruise Control
I just spent a couple of days leisurely installing HD's cruise control and fog lights on my 2006 Street Glide. After having a lot of fun putting the right hand control back together I tested the system before buttoning up the fairing. The red cruise control indication isn't coming on at the speedo. The cruise control switch has power indicated (illuminated). I checked the fuse and it is good and brakes illuminate so I am slightly stumped. Might have to pull the ignition switch and check under the fairing cap to check the fairing connector. Any thoughts would be appreciated.
matt[/align]
matt[/align]
RE: Cruise Control
ORIGINAL: shrinemotorman
On the 07 FLHTCU, the redcruise symbol (cruiseOFF ) and the greencruise symbol (cruiseON/activated) is in the tachometer and not the speedo.Neitherred or greencruise control symbolslight up when the cruise control switch is in the off position.
RE: Cruise Control
The red/orange indicator should illuminate any time the cruise switch and ignition/acc are on, and will turn green when activated. Go check the three pins you inserted in the 12-point switch connector. IIRC, the red goes in pin 5, black (ground) in 12, and the other one in 4. Double-check the manual on that. Make sure each pin is seated properly.
Go through the initialization procedure and see if it works, although you should be able to get an orange indicator immediately after installing. The LED is in the tach on my '07 SG, but in the speedo on some models (Ultras, I think).
RE: Cruise Control
think its in tach as well on ultra. when I first started to put pins in 12 pt connector for switches I just tried to shove them in holes but did not seem to go in smooth. after closer inspection I notice connector opens up on both sides(flap) on male end using finger nails. they then went in easy and seated better. Did you do it this way?
RE: Cruise Control
This topic has been run several times......at the top of page do a search on "cruise control"...you'll
find alot of good info. You have to do an init first....but need to also do roll-off setup...check your
manual......or look at search info accordingly....
I am having trouble getting the search to work.....you might try it.....check my post..it should have
all the answers your looking for.
RE: Cruise Control
52edub,
Just installed the Cruise set-up on my 2006 SG two days ago...
I went out to the garage to check when the Cruise Control light actually comes on.
1. Ignition Switch to on
2. Fairing Cap Cruise Switch ON
3. RED light ON Tach.
1. Ignition Switch to ACCESS
2. Fairing Cap Cruise Switch to ON
3. NO light on Tach.
It seems if you have NO light in either sinario you may have a miss-wire at the fairing cap connector.
RE: Cruise Control
ORIGINAL: voodoodrug
No, I didn't do it that way, but you did it the right way. I just crammed them in with a small screwdriver instead, and didn't notice the right method 'til I stumbled upon it in the service manual later on. They did not go in easy, but I made sure they were seated properly, and they apparently are since everything works.
RE: Cruise Control
ORIGINAL: fryeca
52edub,
52edub,
