Another Amp Install Question...Sorry!
Sorry if this topic is beat to death but I searched and couldn't find an answer. I have the RF PBRX4, Sony head-unit, fairing and fairing lower speakers, so 4 altogether. Power lead is good, so is ground. Now this is where my brain fried at midnight looking at all the wires!! The 2 upper fairing speakers, we cut the (+) and (-) just before the speaker. The leads from the head-unit now get soldered to the (+) and (-) of the adaptor I cut the RCA's off of and plugged into the 'input' side of the amp, and my other adaptor soldered to the (+) and (-) gets soldered to the leads going to the speaker and plugged into the 'output' side of the amp, correct? This is what I did and no dice!! I'm no car audio expert but am I missing something really simple or am I completely backwards with the wiring? Gains were in the middle, didn't touch any other setting apart from switching back and forth from 2ch to 4ch since I thought lets get the upper speakers working and then wire the lowers. Just put chrome lower on and mono-tubes and it was a piece of cake compared to this...what am I missing? Any help is really appreciated!!
Should the power light be on on the amp regardless of the bike ignition being on? And when you say 'series' as in taking the both front (+)'s and (-)'s soldering together and then onto the adapter wires? Sorry if this seems basic stuff but I have to be missing something or perhaps I have a bad amp.
The 2ch/4ch switch on the amp should be on the 2ch setting. This switch is on the 'input' side of the amp, so I'm pretty sure it is telling the amp how many channels the input is. That is how I have it set up on my street glide with stock head unit and speakers in the fairing and lowers and it works. As far as the light being on on the amp, I believe that would depend on whether or not your stereo is on. I'm not sure about the Sony head unit, but for the factory head unit, the outputs (that originally were wired to the fairing speakers) act as line-level inputs into the amp, so the amp turns on/off when it senses an output from the stereo. If you use the RCA inputs for the amp, i think that is when you have to use the switch for the amp to manually tell it when to power the amp on/off.
Can anyone confirm?
Can anyone confirm?
I suppose it may be nice to be able to adjust the volume levels between the fairing and lowers speakers so that it is hitting you evenly. But as long as there is sound and it is clear and loud, at this point that's good enough for me.
benson1603
Audio Systems
02-09-2019 01:54 PM
Harleypingman
Audio Systems
131
06-14-2016 07:03 AM
