Noisy valve train
Old 07-29-2005 | 11:17 AM
rm4040's Avatar
rm4040
Default Noisy valve train
I have a 05 FLHT and it has allot of valve train noise. I know the push rods are solid and was wondering that maybe there is too much clearance which accounts for the noise. Would replacing the push rods with adjustable rods properly adjusted quite the noise or is there something else that can be done. Every once in a while it seems the a lifter may stick.
Old 07-30-2005 | 03:12 AM
pilot1996's Avatar
pilot1996
Default RE: Noisy valve train
How many miles? It's been said, (and it seems like I'm saying it a lot lately) on this forum that many a valve train noise when away after adjusting the primary chain...
Mac
Old 07-30-2005 | 09:46 AM
HDF Tech's Avatar
HDF Tech
Mac makes a good point here. Are you sure that the noise is coming from the valve train and not elsewhere. Harleys are noisy motors also. If you have solid pushrods in your motor as you say ,you'd be the first, this could be why it is so noisy No oil to the upper end!
Old 07-31-2005 | 12:00 AM
RIEDEL's Avatar
RIEDEL
On my 01 Ultra; the motor gradually made more noise. The first place I looked was the primary chain, but it ended up that one of the cam tensioner bushings had worn through. About 22,000 miles.
Robtarra39
05-01-2016 11:37 AM
sdfireman
06-26-2014 05:25 PM
Road Star
Exhaust System Topics
03-28-2013 09:32 PM
faither
10-29-2012 07:23 PM
nemick
07-06-2010 09:35 AM
Quick Reply: Noisy valve train
