Wiring Question
my question is - which pins on the existing harness do I need to relocate to which positions, so I don't have to pay the $30 for an unnecessary pigtail...
I used the wiring harness # 69200441. It's very easy. The only problem was locating the correct wire to add the wire harness to. I’m very happy with the results. The nice thing is it is reversible and I can take it with my to another bike if I buy one it can be used in.
MY bike is a 2012 FLHTCU
You're wanting to keep your passing lights on when the headlight is on high beam? It can be done without a additional harness. Turn your forks full left, in the lock position. On the right side, up under the switch panel, you will find a plug. There's enough length on the harness to pull it out. It's like a 8 pin connector IIRC. One end of that plug has an orange and yellow wire. All you have to do is switch the wires, putting the yellow where the orange was and vice versa. Easy peasy, once you get the pins out of the socket. Be advised that once this is done, the passing lights will not turn off with the ignition switch. You have to manually switch them off. There was a thread about this a week ago, with pics, but I don't remember the title.
i got the pigtail to go with my led headlights and aux lights after installation and riding a day or two at night. i followed the installation instructions, taking off the fairing but still had to take a few minutes to find the wire sections. if you are ok taking off the fairing, its an easy swap once you find the wires. mine were to the left side of the radio, as you face the bike, back toward the left side of the gas tank and you could hardley see it. when i located them and pulled them out, took about 30 seconds to add the pigtail. lights stay on when the ignition switch is on and go off when the bike is turned off. aux lights can also be turned off with the aux light switch on the left side of the switch pannel. it was a good mod but didn't give me the results i was hoping for. not real satisfied with the led upgrades. would not by the $500 daymaker if i had it to do over again.
