Front disc warping after 6k miles??
Old 04-08-2012, 12:02 AM
DeneFXDWG's Avatar
DeneFXDWG
DeneFXDWG is offline
Default Front disc warping after 6k miles??
Went for a ride today and I started thinking that for a while now there is a uneven surging coming from the front brakes. When the rear only is actuated it is as smooth as always. I don't ride my brakes and not hard on them so is this unusual for a newer 2011 bike please? I feel no pulsing through the brake leaver but a definite uneven surge from the front. Will the dealer give me a hard time and possibly not cover this under warranty?
Old 04-08-2012, 12:56 AM
drukanfu's Avatar
drukanfu
drukanfu is offline
Should be under warranty.....One caliper must be sticking, not any reason for him to go Opra on you ?
Old 04-08-2012, 01:02 AM
2black1s's Avatar
2black1s
2black1s is offline
I had one front rotor replaced under warranty on my 2011 Limited. Just measure the runout. If it's .008 or more they should replace it.
I measured mine at .008. Took it in and told them, they verified my measurement and replaced it on the spot.
No hassle at all - except I tried talking them into giving me the rotor so I could replace it myself and they wouldn't go for that.
Old 04-08-2012, 02:13 AM
dickey's Avatar
dickey
dickey is offline
Received 5,651 Likes on 2,536 Posts
My car's been doing that for the last 4 years.
Old 04-08-2012, 04:49 AM
dc1450's Avatar
dc1450
dc1450 is offline
They shouldn't give you any problems, Brembo rotors wear out faster than the tires. I don't get the hype, they kinda suck. Mine warp every 10K.
Old 04-08-2012, 09:00 AM
AlanStansbery's Avatar
AlanStansbery
AlanStansbery is offline
My experience is, the stock Harley rotors--those provided with pre-08 bikes as well as those (11.8") provided with Brembos--warp pretty readily. I suspect at least in my case, one hard stop is about all it takes, or one 10 or 15 mile ride downhill on a twisty mountain road. They heat up, and warp. I think it's the design, single piece. Maybe I'm hard on brakes.
I bought some Harley 'floating' discs and haven't had a problem since.
I'd ask the dealer to give me credit for the stock replacement rotors, and use it toward the upgrade to a set of the HD 'floaters'.
Alan
Old 04-08-2012, 09:13 AM
mkguitar's Avatar
mkguitar
mkguitar is offline
no problems - yet- and I do some twisties.
I am always try not to let a hot pad sit clamped on the rotor at a stop.
I am very happy with the recent braking systems esp compared to the evo bagger loaded down. so far, the wear has been very good.
Mike
Old 04-08-2012, 09:18 AM
VTL nut's Avatar
VTL nut
VTL nut is offline
Alan
I wondered that (floaters),
thanks for the heads up.
Old 04-08-2012, 09:21 AM
shortride's Avatar
shortride
shortride is offline
The front rotors on my '09 Ultra Classic were warpped at 5900 miles.
Old 04-08-2012, 10:00 AM
DeneFXDWG's Avatar
DeneFXDWG
Well off to the dealer I go then. Any idea of the cost difference for floating conversion assuming they'd give me credit?
Quick Reply: Front disc warping after 6k miles??
