Anyone seen these bags
I made a couple purchaases from Mutazu on e-bay and they were good to deal with.
I do not recommend buying bags and lids without hardware. I learnt the hard way. As stated previously the hardware is expensive and you have to have a special rivet gun to rivet the hardware on. I found a set of 2012 dealer take offs on e-bay and bought them for what I would have had in piecing the bags together.
Received 73,829 Likes
It's just my opinion though.
Here's a crappy pic of the bike, but you can see the right bag in general. Other then it being dirty (did about 400 miles just before this pic) you can't tell a difference from stock.
Sorry for not responding sooner, I hadn't checked up on the thread. I just got the bike back from the shop on Friday. The fit is perfect. I don't have anything bad to say about them. The latches are actually only $83ish and they do have to be riveted, but thats a quick deal that any indy will do for you for a couple bucks - then they get screwed onto the bags themselves. There are things that you gotta buy in addition to the bags. Weather seal for the inside rim of the tops, rubber fittings that attach to the bottom chrome supports (unless your current setup does not have bottom supports), the quick release hardware (or use whatever your RK did) and of course the latches, lock and face plate. You might be able to find a set of take-offs, but the odds of finding them 1.) in good enough shape for you to not want to repaint and 2.) actually in the color you want; are pretty low. Even after buying all the parts, you'll come out ahead with these bags.
Attachment 243635
Attachment 243635
I'm only replying because of your reference to rivets for the install. I've never bought HD's latches separately, but I have disassembled the bags for paint a couple of years ago, and more recently, removed the OEM lids for the HD speaker lids and didn't encounter any rivets--just the four screws used to secure the latch mechanism to the bottom of the saddlebag, and five scrws to secure the latch mechanism to the lid.
If you care to, please explain the rivets to which you refer. As always, pictures are great.
Carl
furtrader
10-17-2013 11:28 PM
