Stebel Horn
Stebel Horn
I was cleaning the bike the other day and it looked like a Stebel Air Horn would fit under the tour pak behind the license plate? That way I could leave the compressor mounted with the horn. Anyone done this? I will post pics when I get it completed this weekennd hopefully.
Thanks
Thanks
I've not tried that. However, it seems to me that you would be defeating the purpose of the horn. Mounting it under the tour pack would muffle the sound. It would be covered up on all sides except to the rear.. And when you combine that with placing it at the rear of the bike, might as well leave on the stock horn.
You can do a clean install of the stebel under the chrome cowbell- CHEAP.
Remove the horn body from the compressor (cut it off). Then you'll have to JB Weld one hose barb fitting onto the horn body and one onto the compressor so you can interconnect the two. There is room underneath the cowbell for the new horn when you remove the electric pip-squeak. I actually have mine zip-tied underneath (you can't see the zipties- the go around the brackets on the rear). Install the compressor under the seat in that opening in front of the battery. Run a length of hose for your air line between the two. Unless you get on your hands and knees and stare at the cowbell or notice the hose replacing the electric wires, it looks bone-stock. I've had mine this way since early 05.
I mounted a Stebel air horn under the seat of one motorcycle I use to own. As far as sound level, it remained extremely loud and every car around me heard it just fine.
So my comments to the naysayers is that until you have performed a horn mount in an alternative place such as the OP is suggesting, it may be best to speak from experience, not supposition.
To the OP...based on my past experiences with alternate horn mounting positions, mounting the horn under the tour pak will be a workable alternate mounting site. Try to keep the compressor vertical if possible, since that is what the instructions say to do. Direct the sound to the left side if you can. It really doesn't matter much because at 137 dB, those darn horns are super loud and high pitched. They will be heard regardless of the mounting place.
Also, remember to feed that booger with a 30 amp automotive relay....One usually comes with the horn....those small compressors pull about 18 amps at 13.8 volts. Use #14 or #16 gauge stranded wire to feed it. Use the voltage going to the stock horn to energize the relay coil when you press the horn button. In fact, you can just leave the stock horn in place, tap off the spade terminals of the stock horn to energize the automotive relay driving your Stebel, then you have two horns.
On my present bike, I went away from air horns entirely. I purchased an automotive high tone and low tone horn, mounted one under the cowbell, and the other on the steel panel just to the rear of the rear cylinder on my 2010. My horn sounds like a car horn and it's pretty darn loud to boot. I still use a relay to feed these electric horns because they are high output horns and together pull too much current to just run them through the stock horn switch contacts. Good luck with your install.
