"Wallowing" through curves
when bought and picked my flhrc up at the dealer it kidna wallowed threw the curves i found the air was low in tires so i fixed that still not good i gradually icreased air in shocks from 6lb the dealer had it set at to 25lb . rides great . my shocks were 13" then . i now have 11" bitchin bagger drop shocks basically stock shocks cut down . i run 25psi solo 30 psi 2-up .
get a HD no air loss pump if you don't have one already and exspermint with gradually increaassing preasure
The wallow is probably caused by a combination of frame flex and the way the rear motor mount is designed on the older bikes (pre-'09). You can't get rid of the frame flex but you can help with the movement at the rear engine mount and swingarm by installing a stabilizer. There are several to choose from, but IMO Progressive makes the best for the money. It's called the Touring Link. I don't know how this would perform with the Sta-Bo bushings also installed.
I installed the RideStr8 about four years ago and it has helped with the wallowing in corners like you describe, but these devices won't get rid of all of it.
Haven't had a chance to ride because my work schedule sucks, but I am going to experiment with different air pressures in the rear shocks. If I don't notice an appreciable difference doing that, I may consider doing the rear shock oil change that I have read about on here. Anyone have any thoughts about that procedure and the potential benefits of it? I'm really trying to stop spending money on this bike.
