Rear shock advice for big riders??
I have an 11' Electra Glide Ultra Limited. I ride 2 up a majority of the time. Problem is that I am 6'5" 380lbs and my gf is 6' approx 230lbs. I run 50psi in the rear air shocks and it still isn't enough. When we hit bridges, manholes, potholes etc. it bottoms out and jars both of us pretty badly. I am getting ready to go on a 5000 mile trip and was hoping to rectify this before I leave. Other than the obvious solution of losing weight which I am working on. Was 400 a few months ago. Will a good heavy duty shock handle max load? I am open to suggestions but don't want to spend a ton of money. I used the search forum but mostly found lowering shocks and ones for lighter riders. I am going to put in HD fork oil to help the forks out and eliminate some of the dive that occurs when braking etc. Thanks in advance......Craig
I'm 5'10" and 13 stone on a wet day. My Ultra is pumped up to 50lb and bottoms out alla time. A buddy of mine has an 06 CVO Ultra and is experiencing same so he has been on the phone to various knowledgeable manufacturers of shocks in the States and Holland ( we are in New Zealand). The advice he received was to replace the stock shocks as they're not worth wasting your time on them (it was mentioned that the MOCO buys them for 8 bucks apiece and they handle accordingly). Even the best of shocks need to be reconditioned at some stage after 10 to 15 thousand kms but when was the last time your dealer suggested you have your shocks done, particularly during the warranty period? I am waiting for Progressive 430's to come from J&P for me and my buddy.
btw my bud bought some second hand progressives off a dude who took them off his BMW. They cost him a hundred bucks and though not ideal for his bike the bike is "transformed" as a ride experience according to his missus.
I got a set of 13's and really noticed the difference when I hit the same bumps that I could feel a slight bottoming out on. When over it like a Cadillac
http://www.ebay.com/itm/Progressive-...ht_2839wt_1163
You are over Max load if you are 380 and your girlfriend is 230, you're not being hard on your shocks but you are at risk of a catastrophic tire failure at highway speeds.
Unsafemotorcycles.com
Just wondering if you know the Max loaded weight of your bike and if you checked before you bought the bike?
![Lightbulb](https://www.hdforums.com/forum/images/icons/icon3.gif)
You're right to caution against overloading a bike, but quite frankly if I was OP I would simply make the best of my bike. I would run tyres at maximum pressures (ignore the manual, I mean manufacturer's max - email your preferred brand - for Avons it is 50 psi) and fit top quality shocks, as already recommended.
The maximum weight for an Ultra's front tyre is around 639 pounds, rear is 1019, so with bike weight of 889, plus riders at 380 and 230, 1658 plays 1499. So OP has a safety margin on his tyres of 159 pounds, even though the two of them may exceed the bike's GVWL.
I wouldn't be concerned about loading the bike up for that 5k mile trip. I don't imagine they are going to be attempting any record breaking speeds!
The economical and serious upgrade in ride quality and comfort is Ohlins #3-3s out back and fabrik8r's magic upgraded Intiminators plus springs up front.
