Lower engine temp with soft lowers
After reading a post by MKguitar that his bike runs cooler with his factory lowers on I decided to do a test with my after market soft lowers "desert dawgs". I have a 2007 Roadking. Fact: On an 85 degree day in california I made four runs over the same route in the same temp. Letting the bike cool for ten minutes and then completing the route, which was about 45 minutes long. Twice with the soft lowers on Twice with them off. Average head temps for the two runs without the lowers were fron 311 front and 345 rear. With the lowers on 275 front 330 rear. Temps measured at the same spot between the head bolt and the spark plug. I know that there will be a lot of people chime in and say it takes 50 tests and maybe my method was not scientific enough. I will add to the post as I do more tests. I have an oil-temp gauge and the oil temp only dropped very, little barely noticable. If you look at the bike with the soft lowers on though they for a funnel towards the heads makes sense. Only draw back your feet get a little warm but you can always put them on the higway pegs.
jeez, website acting up...
cont'd;
I use oil temp as I hope it best indicates an average of motor temps, the hottest areas being the pistons, cylinder bore and heads. Oil carries heat from these areas to be dispersed.
testing was on my 1995 FLHTC 80" evo, stage 1.
( which typically has lower operating temps, BUT less oil volume/pressure and does not have piston skirt oil cooling jets. The evo has generally the same shape motor, with similar fender, forks, fairing and other aero-dynamic features as on current models)
2 X 22 mile loops at 55 MPH ( I live by a freeway) at ambient temp of 105º, low humidity- test conducted within the same hour.
1 with hard lowers ( unvented) on, one with hard lowers off.
Oil temp was 25º cooler with hard fairing lowers on.
"test instrument" was the HD thermometer dipstick, which was tested for calibration against my wife's expensive candy thermometer ( Don't tell her ! ). The HD tested accurate all the way up over 300º
Mike
cont'd;
Mike
