SE compensator woes - loose bolt problem - nice fix
Old 04-02-2012 | 05:05 PM
speakerfritz's Avatar
speakerfritz
Default SE compensator woes - loose bolt problem - nice fix - harley primary noise
someone posted this over the weekend and I orderd one today.
http://www.automotivemachine.com/ind...emid=53#clbolt
SO the SE compensator has a problem with the retaining bolt being loose. heres a great idea. a retainer that locks the bolt in place. reminds me of my aircraft maint days.
Here are some pictures and part numbers. Just got off the phone and ordered one.
The first pic shows the underside of the a retainer from the earlier SE 40274-08 kit. This retainer has external splines (like a gear teeth) on the underside.
Retainer from 40274-08 SE kit. If you have the 40724-08 SE kit, you can simply call and order an LP08K and a predrilled retainer (p/n 37810-08A). There's no need to send your retainer.
The next pic shows a retainer from the latest SE 40274-08A kit. It has a smooth cylindrical surface on the underside, as seen on right side of retainer in the pic):
Retainer from 40274-08A SE kit. If you have the 40274-08A kit, you will need to send the retainer and flanged hex head 9/16" bolt.
Attached Thumbnails SE compensator woes - loose bolt problem - nice fix-2-se-comp-40274-08.jpg   SE compensator woes - loose bolt problem - nice fix-08b-comp1.jpg   SE compensator woes - loose bolt problem - nice fix-08b-comp4.jpg
Old 04-05-2012 | 02:42 PM
speakerfritz
here is the basic SE comp bolt.
Attached Thumbnails SE compensator woes - loose bolt problem - nice fix-photo-9.jpg
Old 04-05-2012 | 02:43 PM
speakerfritz
on the left is stock. on the right the modified kit which includes pre-drilled unit, retainer, and bolts for the retainer
Attached Thumbnails SE compensator woes - loose bolt problem - nice fix-photo-8.jpg
Old 04-05-2012 | 02:44 PM
speakerfritz
here is the new unit assembled
Attached Thumbnails SE compensator woes - loose bolt problem - nice fix-photo-11.jpg
Old 04-06-2012 | 03:26 AM
jty's Avatar
jty
Default Fixed link
There is an error with the posted link. Here is the right one:
Old 11-16-2012 | 07:13 AM
hammr_hed's Avatar
hammr_hed
Great info from many perspectives...ordering parts today. One question tho...I've been running amsoil in the primary....is no one using amsoil after the upgrade?
Old 11-16-2012 | 07:47 AM
09 YELLOWBIRD's Avatar
09 YELLOWBIRD
Great find!
Please keep us informed once you have put some
miles on your SE Comp. Seems like this may end the dreaded
replacement of the the SE comp.
Ride Safe,
YELLOWBIRD
Old 11-16-2012 | 08:56 AM
harleycharlie1992's Avatar
harleycharlie1992
Unofficial HDF Chaplain
thanks for this tip!!! just ordered one, the guy, Steve very nice to deal with, and very professional. will put one on mine, and most likely will start including it on customers bikes jobs, great insurance
Old 11-16-2012 | 08:57 AM
harleycharlie1992
what does oil have to do with this?
Old 11-16-2012 | 10:59 AM
hammr_hed's Avatar
hammr_hed
wrong post...oops...lol I was reading two threads. The other was the SE compensator installation. I was wondering if anyone was using Amsoil after the upgrade. No mention of it at all in 33 pages.
Quick Reply: SE compensator woes - loose bolt problem - nice fix
