SE compensator woes - loose bolt problem - nice fix
Old 11-16-2012 | 01:13 PM
DTTJGlide's Avatar
DTTJGlide
I hadn't heard of a problem with the bolt coming loose, just a lack of lubrication causing gauling.
Old 11-17-2012 | 06:35 AM
lionsm13's Avatar
lionsm13
I've heard of the bolt coming loose, and I've also heard of the gauling issue.
Old 11-17-2012 | 07:01 AM
HDV-GLIDE's Avatar
HDV-GLIDE
Wouldn't a small tube of LocTite Red cost less and perform the same function????
Old 11-18-2012 | 07:56 AM
jty's Avatar
jty
Shop manual instructs to use red locktite always when reusing the bolt.
Old 11-18-2012 | 08:16 AM
mike5380's Avatar
mike5380
I upgraded my comp to SE comp at about 10K miles. Now about 25K on the bike and no more issues, torqued and used red loctite. It's gonna have to grenade before I take it apart again to put this latest "fix" in there.
BTW- I changed out my fluid to Formula+ when I changed out the comp, and I overfill slightly to 38-40 oz. No leaks, no noise, no problems.
Mike
Old 11-18-2012 | 10:36 AM
Lowcountry Joe's Avatar
Lowcountry Joe
If a new bolt is used with red locktite, then properly torqued (here is where so many screw the pooch), then allow the locktite to set over night, you won't need this piece. That's what I did when I installed mine. That bolt is going nowhere.
I have seen this piece before. However, just think about what will happen in your primary when those little screws back out and they, along with the nice round disk, start their trip through your clutch, chain, tensioner, stator, etc.
Nope, I think I'll pass.
rscott
08-24-2017 08:18 AM
drspencer
03-09-2012 05:15 AM
zman013
Exhaust System Topics
15
07-16-2009 05:37 PM
john lockwood
12-14-2008 02:39 PM
1potter1
10-26-2008 08:55 PM
Quick Reply: SE compensator woes - loose bolt problem - nice fix
