oil temp guage
Old 04-08-2012, 07:45 AM
nvsteve's Avatar
nvsteve
nvsteve is offline
Originally Posted by iclick
Just pull the plug out and insert the OTG adapter quickly. You won't lose more than a few drops.
Did you use any type of sealant?
  #32
Old 04-08-2012, 08:16 AM
62hdbiker's Avatar
62hdbiker
62hdbiker is offline
I used teflon tape sealant. Did the job when the motor was cold (thicker oil). Was quick to shove adapter in and lost maybe 1/2 OZ of oil. Have 15,000 miles since and not 1 drop of oil leak. This is 3rd one I've done. Learned to wire gage before installing as pointed out earlier.
  #33
Old 04-08-2012, 08:17 AM
iclick's Avatar
iclick
iclick is offline
No need. It is a pipe-thread fitting and there is no pressure, so leaking shouldn't ever be a problem. With the HD OTG you could put Teflon tape or other sealant on the adapter if you wanted, as the sender is grounded independently (separate wire). Other types like the McEwan gauge may ground at the sender and for those I would not use sealant, as it may impede the ground connection. Also, if you use sealant, do so sparingly, as you don't want any loose Teflon tape or other foreign matter floating around in your oil lines. Bottom line: IMO, don't use it.
  #34
Old 04-08-2012, 08:24 AM
Lowcountry Joe's Avatar
Lowcountry Joe
Lowcountry Joe is offline
Just finished the install in my Ultra Ltd. Guage and sensor working fine. I also have the HD digital temp dipstick. The dipstick temp and the oil pan sensor read very close to each other, within about 5 degrees. That's close enough.
I'll be happy to answer your install questions in a PM. The Ultra kit and install is different than some of the stuff I have been reading in this thread. So not to belabor that here, you can PM me if you want to ask me any questions about my install experience on an Ultra Classic.
  #35
Old 04-08-2012, 01:54 PM
iclick's Avatar
iclick
iclick is offline
Do current kits have a harness or adapter to plug the gauge (ground and 12V) into the existing ATG harness on the bike? Mine didn't and I needed to fabricate one.
  #36
Old 04-09-2012, 08:07 AM
62hdbiker's Avatar
62hdbiker
The kit I bought last November hooked directly to the ATG for power and ground.
  #37
Old 04-10-2012, 10:58 AM
iclick's Avatar
iclick
iclick is offline
It's good they've come around to this idea, sparing owners from making a harness.
  #38
Old 04-10-2012, 12:29 PM
nvsteve's Avatar
nvsteve
nvsteve is offline
This is the one I have on the way.
http://www.parts4powertoys.com/en/products/details/7--2
avonflhtk
07-02-2016 07:40 PM
alarmdoug
2014-2023 Touring Models
07-13-2015 05:22 AM
raybaby
03-02-2010 01:28 PM
ms3300
11-10-2008 12:26 PM
RandyD123
05-17-2006 11:08 AM
Quick Reply: oil temp guage
