oil temp guage
Old 04-01-2012, 02:42 PM
1st 96 ultra's Avatar
1st 96 ultra
1st 96 ultra is offline
bought one from Orilley for like $30 for the complete kit , not a exact match but to save $100 , works just fine , could have kept looking and got closer I think
Old 04-01-2012, 08:30 PM
FL-kruzen's Avatar
FL-kruzen
FL-kruzen is offline
I bought the Harley gauge from my local dealer and installed myself. Very simple install.
Old 04-01-2012, 08:39 PM
HogglyWoggly's Avatar
HogglyWoggly
HogglyWoggly is offline
I bought and installed one of the 'non Harley' gauges and before I got the fairing back on I decided to change it out to the Harley model. The one I bought didn't exactly match my existing gauges and, while it wasn't THAT obvious it bothered me. I guess it all depends on how picky you are.
Old 04-01-2012, 10:00 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Lowcountry Joe is offline
Originally Posted by Sparky73
How long did you have to wait for your gauge from LSHD? I've had one on back order from Surdyke for 6 weeks and starting to get a little pissed.
I think it was about two weeks or so. I have been waiting for the Titanium colored oil temp guage ever since I purchased the bike back in 2010. As a Limited, it has existing Titanium guages, so I needed the oil gauge to match.
The oil sending unit cable, according to instructions, works over to the right frame tube, up to the neck then along (under) the existing wiring harness then into the faring.
My issue is with the supplied pan adapter. The sending unit will not screw into the pan adapter much more than about 2 turns. I have called LSHD and sent a photo to show what I am talking about. Here it is:
Old 04-02-2012, 07:21 AM
katobird's Avatar
katobird
katobird is offline
O rielly auto parts 25.00 bucks.
I really dont care about the match...very close.
I did use a red sharpie on the bulb
works good and the red tint matches the rest of the gauges
Old 04-02-2012, 12:01 PM
Majic31's Avatar
Majic31
Majic31 is offline
Default Can someone who's installed the HD gauge kit answer me this -
I have bought the HD gauge kit and have been waiting for my next servicing to have it installed.
I would like to install it myself, but was wondering - how high does the oil level sit in the pan???
What I mean is - if I remove the plug to install the sensor, am I going to have oil leaking out on me??
Or is the level below the plug hole and I can get this done w/o making an oily mess?
I know it's an oil temp gauge and needs to have contact with the oil to measure the temp (duh)...
but is it sitting in oil the entire time, so I have to drain oil to install, or can it be done on a cold engine without removing any oil?
Also - I am thinking I want to move the Voltage Meter Gauge over to replace the Air Temp, and place the oil temp gauge with the oil pressure gauge.
That way - one glance and I can see how my oil's doing, rather than having an oil gauge on each side of the fairing.
Has anyone done that? do I need to extend any wiring, or can it be done with just moving things around?
Thanks
Old 04-02-2012, 12:55 PM
Lowcountry Joe
You have to drain the oil. High temp Pipe sealant is required on the brass fittings. Gotta get the hole clean of oil so sealant will cure. Takes several hours to cure properly. Worth doing right since you could lose your oil if it comes out. I would never trust the dealer to do this install. But thats just me.
Old 04-02-2012, 01:55 PM
nvsteve's Avatar
nvsteve
nvsteve is offline
Interesting. I've read that draining the oil is not necessary and not to add any kind of sealant. The threads are tapered and are self sealing.
EDIT: I just read the HD instruction sheet and they do say to drain the oil and use Locktite 565.
The instructions for the aftermarket model from parts4powertoys says the opposite.
Go figure.
Old 04-02-2012, 02:59 PM
HogglyWoggly
Thanks
I did not drain the oil when I installed mine ('11 Ultra Classic). I had mine on a jack and just removed the plug and let it drain down to a dribble and then installed the plug with loctite.
I also moved the amp meter to the left side of the fairing below the fuel gauge and placed the oil temp below the oil pressure. Just a matter of moving some wires around. Pretty straight forward install.
Old 04-02-2012, 08:04 PM
Lowcountry Joe
Drain down to a dribble? Sounds like you drained the oil to me!
Anyway, Loctite 565 is a high temp pipe sealant more than it is a thread locker. Permatex makes a substitute if you can't find the Loctite product locally...and it is hard to find locally.
I don't think that either product will set up properly in an oil contaminated thread. That's why you drain the oil, remove the plug and clean the pan threads, apply the appropriate pipe sealant on the brass pan adapter (and the sending unit threads), install both and let it set up for 24 hours, then refill the oil. Getting in a hurry on this project is not a good idea IMHO.
There is no torque spec in the HD instructions. In fact, the HD instructions are very poorly written and illustrated in my opinion. I'll probably go up close to the drain plug torque value, but not all the way since this is brass and the threads are somewhat self sealing anyway.
Quick Reply: oil temp guage
