Jiffy stand safety
Old 03-28-2012, 09:05 PM
Bigdave12768's Avatar
Bigdave12768
Bigdave12768 is offline
Default Jiffy stand safety
I was just looking at the changes to 08 and it says you can not start bike if the jiffy stand is down. I have forgotten to put it and it just pops up as I go. So obviously my bike doesn't have this or it was disconnected. Any one else have this on bike???
Old 03-28-2012, 09:18 PM
Airborne350G's Avatar
Airborne350G
Airborne350G is offline
Were you holding the clutch in? The you can start it. Try it without the clutch in.
Old 03-28-2012, 09:27 PM
Bigdave12768
No I was reading the tech form.pdf and it talk about not being able to start bike with Jiffy stand down. My bike starts leaning on its side in neutral.
Old 03-28-2012, 09:32 PM
JohnScrip's Avatar
JohnScrip
JohnScrip is offline
I see these things a lot -- 3 HD's -- 1996, 2008, 2011. No restrictions on starting, period. Doesn't matter if the stand is down, doesn't matter if I'm in gear (it'll even try to start in gear - ask me how I figured that one out), doesn't matter if the clutch is in. As long as the switch is on and you press the button, there she goes.
THAT SAID: My buddy has an 2007 that he swears won't do a thing unless his clutch is in. Neutral or not.
I'm not saying that I know - I'm just saying that I know what I know.
Old 03-28-2012, 09:34 PM
firefighter616's Avatar
firefighter616
firefighter616 is offline
It is part of the European wiring code.
Bigdave12768
I know if its not in neutral it wont start. It has the button under clutch handle
Old 03-28-2012, 09:37 PM
Copyless's Avatar
Copyless
Copyless is offline
What you should know is, there is a problem with your bike if it starts in gear without the clutch dis-engaged.
Old 03-28-2012, 09:39 PM
Bigdave12768
Old 03-28-2012, 09:40 PM
Bigdave12768
So its not around here?
Old 03-28-2012, 09:53 PM
kajunkruzer's Avatar
kajunkruzer
kajunkruzer is offline
Saw a guy drive off tonight with his kickstand down, looked like a newer bike, but not sure on the year model.
Quick Reply: Jiffy stand safety
