It's now down to a SG or EGC... Handling question
Old 03-27-2012, 01:00 PM
Tony P's Avatar
Tony P
Tony P is offline
Default It's now down to a SG or EGC... Handling question
Okay... I was looking at a Road King, but changed my mind when I realized that of all the baggers I've demo'ed, I like the way the Street Glide handled at low speeds. It never acted its size and I felt comfortable on it. Looks good to.The Electra Glide was sweet ride as well, but not quite as light on its front paw as the SG. I may be answering my own question, but is this because the SG runs a 130/70/18 front? The SG tire runs a lower profile, but overall size should be comparable to the EG, which runs a higher profile 130/80/17. I think the EG wheel may be a bit heavier as well, which adds weight to the front. Also, does the slammed rear-end of the SG add to this feeling of light turn-in?
I ask this because as much as I like the SG, the EG with a detachable tour pak, etc, would be more practical (less expensive) over the long haul if I ever decide I want a full-on touring rig. Not thrilled with the looks of the EG compared to the SG, but again, it may be the more practical purchase. Thoughts?
Old 03-27-2012, 01:08 PM
Cowboy Rob's Avatar
Cowboy Rob
Cowboy Rob is offline
Big Kahuna HDF Member
Received 2,574 Likes on 1,498 Posts
I would say the biggest reason the SG felt lighter was because the EGC has a tour pak,and the SG doesn't. When you take the tp off,it will feel like a different bike. You would be amazed at the difference in a EGC/UC/FLHTK without a tp.
Old 03-27-2012, 01:11 PM
Topcop's Avatar
Topcop
Topcop is offline
I would suggest that you go ahead and buy the EGC. Put a quick detach kit on the tour pak, take the driving lights off and you suddenly have the best of both worlds. I personally like the driving lights. You can never have enough light on a scooter both front and rear. Just my 2 cents worth and your mileage may vary. Happy Trails...
Old 03-27-2012, 01:12 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
You've put your finger on the slight differences between these models.
The dropped rear of the SG should make the low speed handling a little stiffer and enhance high speed straight line--- maybe.
But cornering clearance is reduced, as it suspension travel by over 30%
The weight of the EGC is a little more with maybe 35# of tourpak swinging around up high
Either of these bikes is capable of handling better than I can ride- lean farther etc.
I have the EGC.
added fairing lowers, SG pass pegs and 2010 RK rear signal bar/plate mount, cut down windscreen ( rotozip on the bottom edge)
with tour pak off and SG shocks, and solo or SG seat in town:
when I tour, it's tour pak on, stock rear shocks ( for floaty Cadillac ride), big seat and taller windscreen
Mike
Old 03-27-2012, 01:16 PM
Dawgtraxx's Avatar
Dawgtraxx
Dawgtraxx is offline
You can put the detachable tour pak on the SG also
Old 03-27-2012, 01:24 PM
frog13's Avatar
frog13
frog13 is offline
Yep! You can make either out of the other ....... for me it was the Street Glide, I didn't want all the bumpers, lights and extras, but that is a personal choice .....
Old 03-27-2012, 01:33 PM
KCFLHRC's Avatar
KCFLHRC
KCFLHRC is offline
Received 1,301 Likes on 781 Posts
I think the wheels on the SG look like a mistake. But you could have the dealer put the EGC wheels on the SG if you wanted. The SG has a good look that's for sure. Especially that rear fender. Put the chrome Limited wheels on the SG and I think that would look awesome.
Tony P's Avatar
Tony P
Tony P is offline
True. I looked into adding a chopped tour-pak to the SG. It's cheaper removing it from the EGC.
Old 03-27-2012, 01:35 PM
Tony P's Avatar
Tony P
Tony P is offline
I have the EGC.
Mike
Sweet ride! So, you actually take the time to swap out shocks?
Old 03-27-2012, 01:46 PM
Armstronges's Avatar
Armstronges
Armstronges is offline
Go with the sg. It just looks cooler!
Quick Reply: It's now down to a SG or EGC... Handling question
