Which Primary oil to choose? stiffer clutch spring
Old 10-01-2012 | 03:59 PM
Just Me's Avatar
Just Me
Originally Posted by Leftcoaster
ATF my man, ATF (automatic transmission fluid).
It's cheap, can be found anywhere, and designed exactly for this application (HD primary). I have countless years and miles using ATF in the primary - with zero negative issues.
Glad you had good luck with it, I ran it for about 6000 miles and it just cost me $500 for a new trans bearing on the primary cover! My mechanic that has been fixing Harleys for 35 years said it was oil related.
My bike now has 26K, boy, did I ever save a lot on oil!
Just remember this, Harleys have roller bearings not ball bearings like a car so it takes a specific oil like Harley offers. Nothing but Harley oil from now on, another expensive lessen learned!!!!
  #32
Old 10-01-2012 | 04:56 PM
pscyclepath's Avatar
pscyclepath
Originally Posted by Shredding rubber
Cheap *** rotella 15w-40 has the JASO stamp safe for wet clutches. It's what I use in my primary
+1 That is all you need.
  #33
Old 10-01-2012 | 07:02 PM
bigfish_Oh's Avatar
bigfish_Oh
Originally Posted by hd_rolling
I use the B&M non-syn quick shift, no issues.
using this as it is one that Barnett recommends, Jegs is $4.99qt. others will price match. they only one they say not to use is HD +
  #34
Old 10-03-2012 | 04:07 PM
Punjabi Rider's Avatar
Punjabi Rider
Harley primary oil or other specifically made for wet clutch be fine regular motor is for motor only not for tranny or primary or least not for my bike one oil in three hole is just to damn simple got to keep it complicated.
  #35
Old 10-03-2012 | 06:08 PM
skratch's Avatar
skratch
Received 4,379 Likes on 2,547 Posts
Originally Posted by ellerja
now how much do you use?the book says 38ozs.but a quart is 32ozs.does anyone buy the extra 6 ozs?
i buy the gallon jug of rotella from the local autoparts house for less than $12.00 and just measure out 38 oz. so for each gallon jug, i get 3 changes of the primary.
use whatever you need to for peace of mind, but there is nothing magical about hd oil, and it is not so different from other oil. i've been a mech in the military for 20 years, and been riding for 11 and have never seen a failure due to oil. from not running oil, sure, but not from the oil itself. not saying it cant happen, but i've not heard of it.
  #36
Old 10-03-2012 | 06:35 PM
Pondskipper's Avatar
Pondskipper
HD Formula + is a basic 20w50 motor oil rebranded to make money off hapless owners.
  #37
Old 10-03-2012 | 07:46 PM
HDV-GLIDE's Avatar
HDV-GLIDE
and you would know this how?????
  #38
Old 10-04-2012 | 09:51 AM
skratch's Avatar
skratch
he read it on the internet. it must be true
  #39
Old 10-04-2012 | 12:09 PM
Leftcoaster's Avatar
Leftcoaster
Which oil, the primary or the transmission? They are separate you know.
  #40
Old 06-04-2013 | 09:04 AM
atrox88's Avatar
atrox88
Originally Posted by 07RoadHawg
FWIW, Type F ATF is was was recommended to me and I believe I even read that on one of the replacement clutch manufacturer's website (of course I can't find it now). It's designed for older automatic transmissions and designed to lubricate and keep parts cool while allowing good lockup of the clutch plates (and cheap). Just in case you ever want to give it a try.
To the OP - in my opinion, there isn't really a good "one bottle for all 3" oil. Each component (primary, engine, and trans) have different requirements and are best served with an oil designed for each specific application. But that's just me...
Been using type F myself for the reasons stated above. I have had no problems.
Quick Reply: Which Primary oil to choose? stiffer clutch spring
