GPS mount on SG
I'm sure this question has been asked before I've joined, but I gotta ask too. Anybody got a preferred way to mount a GPS (Garmin 500) on a 2011 SG? I'm thinking the only way is to RAM mount it to the handlebar but I really don't want to go that route if I don't have to. Thanks in advance.
Now you see it…
![](http://i488.photobucket.com/albums/rr241/blackpearlStreetglide/FLHX%20Iphoto/fef4f937.jpg)
![](http://i488.photobucket.com/albums/rr241/blackpearlStreetglide/FHLX/IMG_0135.jpg)
Now you don’t…
![](http://i488.photobucket.com/albums/rr241/blackpearlStreetglide/FLHX%20Iphoto/e4609b35.jpg)
I used a RAM Ball mount (About $12.00 I think) and a marine grade fused cigarette lighter adaptor ($15.00 ??). I also went with a 3” RAM Arm ($15.00 ??) to get it a little higher. It takes about 30 seconds to take if off, unplug it, and put it in the saddlebag.
Besides keeping with the SG minimalist style it is much easier to see than a handlebar mount, without moving your head down and to one side. With a little eye movement you can just glance down which is a good thing finding your way in traffic.
At idle it vibrates a little more than a handlebar mount but smooths right out at anything above idle. I have the part numbers and prices on my computer if you want them.
Now you don’t…
Try this: http://www.ram-mount.com/CatalogResu...5/Default.aspx
As long as your clutch bracket still has the mirror hole, you can mount this using the hole for a chrome allen head bolt and chrome washer and nut. Then use the short ram clamp and bracket and you are good to go.
here's my take
https://www.hdforums.com/forum/touri...gps-mount.html
I wanted something when the GPS was off the bike I didn't want the craddle and cables exposed...So I utilized what HD had given me to work with such as the holes for the mirrors in the perches...
I also took a film canister and use it to store the ends in to keep them out and nicely tucked away when not in use...I dressed up the top or the bottom depending how you look at it with a HD Skull to help add to the theme on the bike...
Your going to get allot of different views on this like who has the best motor oil but give it some thought and decide on what YOU want to look at when the GPS is on and when its removed...
paul
paul
A friend of mine had this mount last year when we rode to Rolling Thunder. I liked it and bought it. It's made by Kuryakan and is heavy duty, believe it or not. I have since removed that radar detector cause it was cluttering up the handle bars. But this picture shows you how the Zumo 550 mounts:
![](https://lh4.googleusercontent.com/-hNwijWrc-uI/TyYXBsap4KI/AAAAAAAABz8/3NMbq0ef5b8/s732/IMG_0105.JPG)
With this configuration my handlebars are clean, the GPS is in a central place, the guages and speedo are not obstructed, and when fueling it opens up just like normal. I tapped off of the headlight feed under the faring to feed voltage to the unit.
Now you see it…
Now you don’t…
Now you don’t…
You should change your name to Sweet Potato
![Smile](https://www.hdforums.com/forum/images/smilies/smile.gif)
