Quick PBR300x4 Settings Question
im curious for those of you running the 300x4 how you set it up?
1. did you just use the front input as highs or use both front and rear? (aftermarket deck)
2. where did you put your LP AP HP switch?
3. where did you set your HL at?
4. where did you end up with your gain?
i know these can vary based some on system but im running fairing 6.5's and lowers with 6.5's with an aftermarket deck
2. AP
3. Not sure of your question.
4. Gain is all the way down.
I'm using high-level (speaker cable) inputs. So much better than RCAs!
