21 ruining fender 012 SG, rear holes drilled 3/8 still rub, help?
Put a 21 inch wheel on my 12 street glide with a 120-70-21 Avon cobra, discovered my fender was rubbing ever so slightly (like the width of a piece of paper) so I drilled out the holes like Hogpro suggested on these forums,
Supposidly I should be able to get a 5/16 bolt taped to the tire, however, I can not, it literally raised the fender less than 1/8 of an inch and it still rubs, my fender is now ruined also and will need paint, and I'm going insane... What is the actual solution to this problem?
Good luck, maybe someone else can offer up better advice.
Hogpro
09-20-2012 12:02 PM
