monkey bar help?
monkey bar help?
Trying to run my wires internally on my SG, having trouble running the tbw and the right side wires together. I got the everything, but the tbw thru, but the green plugs keep hanging up. About ready to cut and soder everything, seems to be the only way they all will fit, anyone have any other suggestions, thanks
Do a search on here, there is one of these threads everyday. Everything I have seen says to run the TBW first then the others. I attempted to do it on my SG with my PYO bagger bars but took it to my local indy. $100 bucks ($75 & a $25 dollar tip for doing it same day) and I was out in 1.5 hours. I still have all my hair, all the whiskey that was in the freezer and my wife still talks to me.......well worth it to me.
I have a write up here.
I soldered my tbw wires, ran them through first, then ran the other bundled right side wires through. Use lots of grease and its more push than pull. Maybe try taping that plug and applying alot of grease to is.
Personally, Id start right side over and run tbw first.
Did you have to cut the plug directly off the Harley tbw grip sensor, this is the only part that bugs me going from 3 different color wires to 6, think they should send a guy a free bottle with every set of bars!
