4 ways don`t turn off
Old 03-22-2012 | 01:11 PM
lowflyer's Avatar
lowflyer
Default 4 ways don`t turn off
`09 Roadglide had a snafu yesterday. Turned on the 4 ways and they wouldn`t turn off,radio stayed on, cruise control switch light flashed with them, all this with ignition off. WTF? Started it up and got everything to go off. Anybody have a TSSM act up like this? This unit does not have a security system option so I guess it would be a possible TSM failure. Is this common? I guess to further define, I`m running with a Badlands module also.
Old 03-23-2012 | 05:00 PM
TomWoodgeard's Avatar
TomWoodgeard
Subscribed.... Very interesting scenerio. Very curious ....
Old 03-23-2012 | 10:58 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Normal for CC light to flash if you are not moving. You did not say whether or not you were moving. You must have the switch in the on position to the turn off the flashers (at least on my 2010 you do). Were you moving or sitting still? Ign on or maybe on accessory position?
Old 03-24-2012 | 02:17 AM
131tman's Avatar
131tman
Old 03-24-2012 | 03:58 AM
brettnbama's Avatar
brettnbama
mine did the same thing when I checked the 4 ways after installing the badlands LE and LED signals. I just never got around to reprogramming it before I came back from leave
Old 03-24-2012 | 11:06 AM
lowflyer's Avatar
lowflyer
Glad to see it`s normal. When I installed the stuff I didn`t see any directions about programming (couple years ago). It happened at work while I was on the clock so panic mode set in. Will try the programming steps and see if they apply. Thanks for the link 131tman
j_aguilar5142
Electrical/Lighting/Alarm
05-22-2020 09:37 PM
NorthDakotaSoftail
08-07-2019 04:29 PM
dulley
03-04-2014 10:56 AM
Dallastx
07-22-2013 08:30 PM
Handlebarmike
08-09-2011 11:45 AM
Quick Reply: 4 ways don`t turn off
