Street Glide question
Old 03-21-2012 | 12:46 PM
frog13's Avatar
frog13
The back brake and throttle are your friends, especially at slow speeds. In fact, I have seen many people screw up at slow speed, in gravel adn many other circumstances becasue they don't understand the benefits of staying off the front brake or using the throttle in many cases instead of the brake. On gravel, the throttle will save you many times where the brake will put you down. It seems counterintuitive, but it works ........
Old 03-21-2012 | 12:57 PM
rg_dave's Avatar
rg_dave
They handle very well but if you do something silly like hit your front brake in a full lock turn you will probably go down. Once it starts going over there's not much you can do about it. I've done it twice both times due to stupidity on my part. Once I wipped into a friends driveway and started a uturn and hit my front brake for some reason (I knew better). Second time, kicked my jiffystand down and leaned it over without realizing the jiffy stand was not all the way down. Both times I was able to yank the bike back up from the highway bar still straddling it but there was nothing I could do to stop it once it started going over. Both times my fault not the bike. I'd say the guy you saw was either not paying attention to what he was doing or needs to take a class.
Old 03-21-2012 | 01:02 PM
Iceman24's Avatar
Iceman24
Like other owners state - FLHX is very numble...with right operator & driving skills. Only issue is when these touring bikes go over balance point - you'll be wrestling a 800+ lb. bear to the ground...
Old 03-21-2012 | 01:34 PM
Dr. Tiki's Avatar
Dr. Tiki
I have no problems manuevering mine. It's just heavy and you get used to it.
Old 03-21-2012 | 02:31 PM
Lucky1958's Avatar
Lucky1958
Originally Posted by mkguitar
touring bikes are heavy, slow stability is always a challenge.
The front ends are specifically designed to help with this.
The size of the riders makes little difference, check out some of the youtube videos from jerry paladino, "motorman"
mike
+1 ride like a pro
Old 03-21-2012 | 02:51 PM
t-bear's Avatar
t-bear
I have a friend of mine who dropped his new 1100 Yamaha after 45 minutes of riding, then took the MSF beginner course and dropped their 250cc bikes twice.
It is not the bikes fault LOL
Take your time and learn how to handle the bike and all will be well.
Old 03-21-2012 | 02:55 PM
RollaMo's Avatar
RollaMo
Originally Posted by metfancowboy
Remember in slow speed riding like parking lots,forget the front brake. Use only the rear brake,and you will be surprised how good they handle.
This!
Even tapping that front brake at slow speed with the bars turned just a little will cause quite a few riders to drop the bike.
Old 03-21-2012 | 03:28 PM
wakerider's Avatar
wakerider
I had a Fat Boy for six years and thought it handled very well. Now I own a Street Glide and whatever they did in 09 worked. It handles great through the mountains and IMO it is pretty agile in parking lots.
Old 03-21-2012 | 03:33 PM
Lone Rambler's Avatar
Lone Rambler
Very surprized & pleased with low speed handling of the SG. My son has just turned 14 & has very little riding experence on a 750 yammaha & a 1200 sporty but I put him on the Street Glide & he can do just as well on it as the Sportster, some ways even better where the clutch on the SG is smother.
Old 03-21-2012 | 04:35 PM
jperez434's Avatar
jperez434
Mine handled very well with the stock wheels. A 21" front wheel changed all that. When you start changing the rake and height of the front end then it will start to handle like a Night Train or other raked out chopper with even more weight than those lighter bikes.
RealtorCOSprings
08-28-2023 06:09 PM
kungfupanda
Milwaukee Eight (M8)
92
12-22-2017 11:40 PM
sqdqo
03-10-2016 11:29 PM
SmittyFXDL
03-26-2010 08:11 AM
JWalker
12-11-2005 10:24 AM
Quick Reply: Street Glide question
