Headlight removal on Street glide
You can take the headlight out of the bike without removing the outerfairing.
Good luck
- Remove the screw at the bottom of the headlamp door (chrome ring). Remove the headlamp door
- Remove teh three screws securing the headlamp assembly (located at about 5, 7, and 12 o'clock
- Remove headlamp connector rom headlamp bulb.
Good luck
you can get access eather way listed.....fairing removal no big deal.. but how ever you clean it..make sure you dry the inside of headlight throughly..if not it will fogg... maybe best to apply some alcohol rubbing al after words the blow out with a air hose with light pressure..this should get all the moisture out.. if you happen to touch the bubl use alcohol to clean it before reassembling...
