Notices
how does a oil pump gear break?? and keyway fall off
Old 03-24-2012, 11:25 AM
harley_guy1995's Avatar
harley_guy1995
harley_guy1995 is offline
also when i meant the crank was done.. it was sent to revolution 3000 miles ago
Old 03-24-2012, 03:06 PM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
ditto on the metal fragment theory. if you pull the cam plate in the future, add the intake screen. also go for the super magnet drain plugs. remember.....on a stock harley...the oil pump protects the oil filter...there is no filtering of oil from the sump to the oil pump...filtering occurs after the pump on the way to the engine parts.
Old 02-04-2016, 09:54 PM
MTC_Joe's Avatar
MTC_Joe
MTC_Joe is offline
Stage I
Default Same issue
Have the same issue on an FXR. Turns out the performance valve springs I put in were to much load for the woodruff key and is snaping it off under all the pressure.
Old 02-05-2016, 05:29 AM
msocko3's Avatar
msocko3
msocko3 is offline
Could be bad luck, could be the builder dropped something into the engine and didn't catch it. Could be the crank shifted, whoever tears it down should be able to come up with a cause of failure. I'm betting the oil pump is what failed first. It's very rare an oil pump gear just breaks, usually something causes the gear to break.
Old 02-05-2016, 07:37 AM
Varooom's Avatar
Varooom
Varooom is offline
I am missing something here.
The cam gears do not have keys, they are both splined on the shafts.
Confused Varooom
Old 02-05-2016, 07:44 AM
Wilee's Avatar
Wilee
Wilee is offline
EVOLUTION not Twinkie if its the bike pictured.
bigolfunkyo
Engine Mechanical Topics
04-26-2015 04:17 PM
prochopp
EVO
12-04-2011 09:00 PM
kissfan
Shovelhead
07-27-2011 08:42 PM
jsbridgew
EVO
03-06-2011 06:29 AM
jessebradley
12-04-2010 08:02 PM
Quick Reply: how does a oil pump gear break?? and keyway fall off
