newer wheels on 06 FLHX
Old 03-20-2012 | 08:37 AM
CFH's Avatar
CFH
Default newer wheels on 06 FLHX
ust wondering what i have to do to run the 09-12 touring wheels with the 18" front on my 06 streetglide? thanks in advanced
Andy
Old 03-20-2012 | 09:19 AM
rg567's Avatar
rg567
Axle, spacers, bearings, maybe more or less. I did it on my 06 and it wasn't too bad. I changed the axle out to a newer 25mm one, used the 2011 bearings, and made up some custom spacers. The stock 06 rotors bolt up to the new wheel. I posted a "how to" that you could search for if you needed more info...
Old 03-20-2012 | 09:54 AM
Eric Moore's Avatar
Eric Moore
if your intrested I have a sock set of 09 wheels off my street glide ..near perfect.. low miles... frt tire has about 100 miles on it..I had the dealer swap it out due to tire issues under warrenty... rear tire has maybe 6k miles on it... still in good shape.. I only have the wheels & tires..I reused my pulley & rotors... wheels have bearing in them.. abs.. but that wont affect you or if you want a good time to replace bearings... let me know if your intrested...
Old 03-20-2012 | 10:51 AM
DTTJGlide's Avatar
DTTJGlide
You need a 10-12 SG 18" frt wheel with non ABS bearings, or change out the left bearing on an ABS wheel to non ABS bearing, also need 08-12 25mm axle & 2 non ABS spacers, both non ABS spacers are the same. The lower legs are the same from 00-12 so you just need the same wheel, axle, & spacers from a late model bike with the 25mm set-up. Rear wheel will not fit.
Old 03-20-2012 | 12:07 PM
CFH's Avatar
CFH
thanks for the replys, Eric do you have any pics of your wheels and tires? you can email them to dejong.andy@gmail.com
Old 03-20-2012 | 12:24 PM
thenewrage's Avatar
thenewrage
Doesn't the op have to use his rotors if he is not changing his brakes to the new style?
Old 03-20-2012 | 02:26 PM
rg567's Avatar
rg567
Yes. From what I understand, the new rotors are slightly larger in diameter and will not work with the 06 calipers.
Old 03-20-2012 | 04:29 PM
Eric Moore's Avatar
Eric Moore
sure I have them protected in storage right now.. but I will send you a picture of them on the bike..if you need more info let me know & i will get them out & take pictures of them as well...
Old 03-20-2012 | 04:39 PM
Eric Moore's Avatar
Eric Moore
just incase anyone else is intrested..
Old 03-20-2012 | 09:43 PM
CFH's Avatar
CFH
is that an 18' front? id really like to have them how much you want? i would PM you but honestly i cant figure out how? lol
Quick Reply: newer wheels on 06 FLHX
