Polk MM651 vs J&M vs Rokker vs Other "High End" Speakers
Old 04-18-2012, 08:19 PM
FFeric's Avatar
FFeric
FFeric is offline
Good thread. Right now I have Hawg Wired 6.5's in my fairing with a HW amp. I am thinking about adding speakers to the lowers and possibly speakers in the bag lids. What is the best way to go with the lids? I know HW makes lids with speakers but they are not cheap.
  #52
Old 04-18-2012, 08:38 PM
keith2323's Avatar
keith2323
keith2323 is offline
cycle sounds make some that hold 6x9's and faring factory makes some that hold two 6.5 in each lid for $200 on ebay.. the cycle sound lids look better but cost twice as much too.
  #53
Old 04-18-2012, 09:06 PM
bald1der's Avatar
bald1der
bald1der is offline
Originally Posted by NC_John
I've got the rockford fosgate power series 6.5's AND the polk mm561's (powered by the RF300PBRx2). Sound quality wise they were very similar- maybe some better imaging with the polks (which I was surprised to notice on the bike). I replaced the RF's with the Polks (for the marine grade certification) but hurt a Polk on my way back from bikeweek (after probably 30 hrs of listening time cranked up on the interstate. One of the woofers started working intermittently.
Now- here's the thing. When I called Crutchfield and told them I was having a problem with one the speakers the guy asked me for my order number and said "no problem- sounds like the voice coil is coming apart. I will send you a new one. When you get it, just send me back your bad one." They even emailed me a pre-paid UPS form to send the failed speaker back no charge. They sent a brand new set of speakers to me so I sent them my original pair back. No muss, no fuss, didn't cost me a dime in shipping. That is amazing. When I used to run the J&M's and would have a failure they would not send a replacement until they recieved the bad one at their dock and then had at least a few days to look at it. I lost a speaker right before a cross-country trip one time and they refused to work with me. I had to put my factory speakers back in because I couldn't get a J&M replacment for a week or two while they diddled around. I got sick of that and stopped buying J&M. I don't know if their customer service still blows but I got my fill of it and won't spend any more of my money there.
I've got the RF's in now....will probably run them a while before putting the polks back in. I'm tempted to put the polks in my truck - I have a full set of polks in there now but its a cheaper series (dB).
+1 Crutchfields customer service is A+..... I love my Polk MM651's
  #54
Old 04-18-2012, 09:27 PM
keith2323's Avatar
keith2323
What about the polk DB 6.5? anybody runs those???
  #55
Old 04-19-2012, 08:17 AM
GLACIERPEARL's Avatar
GLACIERPEARL
GLACIERPEARL is offline
Originally Posted by keith2323
GLACIERPEARL check out the specs on the polk pa d4000.4 amp and tell me what you think...I love the amp,but i would like to hear your honest opinion what you think about it...
Seems like a decent amp,.........the GLARING difference between the Alpine PDX-F6, versus the Polk PA D4000.4,...........is the THD. Total Harmonic Distortion on the Alpine is .003...............the Polk is .01.
In simple math terms,....................the Polk has 3.3 times more distortion than the Alpine.
How this converts to the final product out of the speakers ........... I don't know.
Polk does make some good stuff though.
Not always , but usually...........you get what you pay for. The Alpine is twice the cost of the Polk. Is it twice as good ?? I doubt it. Is it better. I surely think so.
Either way,...........it should sound good on your bike. I have 2 of the Alpine 600watts stacked, so I have 1 dedicated 150 watt channel for each speaker, ( 8 ).
Good luck with your system !
  #56
Old 04-19-2012, 09:22 AM
dbell66253's Avatar
dbell66253
dbell66253 is offline
I had the Polk DB series 6.5s and traded them out for the MM series, the DBs are good, but the MMs sound better, much better mid range and high which you hear more on the bike anyway. Crutchfield has been running a sale on the MMs for awhile, a couple of other places have them slightly cheaper, but Crutchfield has great service so I went with them. Remember the MMs are 2.7 ohms, they will work with a 4 ohm amp, but I would advise having an amp that is 2 ohm stable.
  #57
Old 04-19-2012, 10:31 AM
murph's Avatar
murph
murph is offline
I have my mm651s paired up with the Rockford PBR300x2 which is 2ohm stable. It rocks.
  #58
Old 04-19-2012, 02:27 PM
DooZ's Avatar
DooZ
DooZ is offline
Planning on using the MM691's (6x9) in cyclesound lids, I have the MM651's in the fairing. Anyone with experience with the MM691's? I'm pleased with 651's, and expecting the same results with the 691's.
  #59
Old 05-15-2012, 08:09 AM
teester's Avatar
teester
teester is offline
bald do you have mm651's in the tour pak pods? If so how did you fit them in? I have a set coming to put in there if I can make them fit.
  #60
Old 05-15-2012, 08:58 AM
trnewman's Avatar
trnewman
trnewman is offline
Could I run 4 Polk MM651's (2 in fairing, 2 in lowers) using only one PBR300x2 amp? Or would I need 2 amps?
Quick Reply: Polk MM651 vs J&M vs Rokker vs Other "High End" Speakers
