Street glide ?
Old 03-19-2012, 06:24 AM
ppilotmike's Avatar
ppilotmike
ppilotmike is offline
Default Street glide ?
So I love my new SG, but can't get used to not having that "Harley" taillight. Anyone ever add one to 2010+ SG? I think the internationl bikes come with one? Wonder if it requires a new rear fender or can be aded to the existing flat space above the T/S bar?
Old 03-19-2012, 07:39 AM
dansflhti's Avatar
dansflhti
dansflhti is offline
I feel just the opposite to you.I wish we(Canada) could get the Street Glide up here without the tail light.
Old 03-19-2012, 07:43 AM
jb27's Avatar
jb27
jb27 is offline
They sell a conversion light for the three-bar light at the bottom of the fender that makes it a run/brake light. I don't think that's what you are asking for, but maybe something to consider to keep the back clean and add another brake light for safety.
Old 03-19-2012, 07:50 AM
sknyfats's Avatar
sknyfats
sknyfats is offline
I picked up the HD "kit" that turns the lower rear tail light into a brake light, so it's not just a running light. For my 2012, it was $129 plus tax. Took 10 minutes to install - looks and works great & adds a little more piece of mind. I also have the Custom Dynamics LED turn signal kit - front and rear with smoked lenses which uses a single load balancer module. $200 for that. Very pleased! Pics coming in a new thread showing all my mods later today
Old 03-19-2012, 07:51 AM
hd_rolling's Avatar
hd_rolling
hd_rolling is offline
Do a swap with one of the Canadian members?
Street Glides are suppose to be clean and custom, the two bullet red lights are brighter than the solo center stop light. If you added the center stop light and converted the turn signal into stop/turn then it would be brighter but seem like a lot of work to make your bike look like an older model or worse like an ultra with a removed toupac. Might as well add the pancake turn signals?
Old 03-19-2012, 07:54 AM
rjmac53's Avatar
rjmac53
rjmac53 is offline
keep the clean SG setup.
Old 03-19-2012, 08:47 AM
hoethree's Avatar
hoethree
hoethree is offline
Model year 2006 thru 2009 had the tail light I believe then dropped on 2010 and newer. Correct me if I am wrong here.
Old 03-19-2012, 08:54 AM
badger34's Avatar
badger34
badger34 is offline
xxxxx
Old 03-19-2012, 09:50 AM
frog13's Avatar
frog13
frog13 is offline
Have you looked at this?
Center-Mount Auxiliary Running & Brake Light
Brilliant red center-mount running and brake light grabs attention of following vehicles. The fast-acting long life LEDs glow red when ignition is on and intensify when the brakes are applied. The low-profile chrome shell attaches to and hugs the contour of the turn signal bar for a custom look. Plug-in connection for easy installation.
68000029
Old 03-19-2012, 09:51 AM
JoeTag's Avatar
JoeTag
JoeTag is offline
IMHO, I like the three-bar better.
Quick Reply: Street glide ?
