Tuner question
Tuner question
hello all.... getting ready to add a programmer/tuner to my 2012 streetglide... it is all stock right now...with the exception of a pair of rush slip ons... 2" baffles,will be changing to the 2 1/2 " this week.not looking to go fast, but will be adding the higher flow air cleaner also.probably will not do any other engine mods anytime soon.. under warranty..just want to make sure doesnt get lean or run too hot ... I have read and read, but have decided to ask the people who put the rubber to the road.. i would like something dependable that i can set up(laptop possibly ) and forget it..what experiences (good and bad) have you had? and what do you recommend?.. thanks in advance for your input
Installing a tuner will pooch the warranty, if they know about it.
basically changing the pre-programmed mixture to "user" settings puts the onus on the "user" to ensure that the mixture doesn't burn up the motor.
Defeating the rev limiter is another basis for voiding the warranty.
It has also been stated that adding a "piggyback" tuner can introduce intermittent resistance to the sensor data, causing ECM miscalculations
Fuelmoto is a forum sponsor and lots of riders here are happy with their sales and after sale service of "mostly" dynojet stuff, power commander, power vision.
However the system which appears to get the least number of rider complaints, questions and concerns is the thundermax.
I myself use nightrider.com XIEDS ( $125) on my 09 FLHTC with high flow air cleaner and tuned Supertrapps. ( my headers have no catalytic convertor).
The xieds plug inline with the o2 sensors, and are quickly removed for that dealership visit for a recall or other service.
I have very good result, and I leave my motors at stage 1 so it should be all I need. MPG is 43 at 70 MPH cruising ( check some of the mpg complaints from tuner users)
The dealer may offer to sell you stuff "cause it won't void the warranty"- if they say that, get it in writing as the dealer service guy can't re-write the terms of the factory warranty.
If you are looking at a high flow air cleaner, the best bang for buck ( and easier install) is the Ness Big Sucker, w/ chrome backing plate for about $120 on ebay from easternpc
Mike
Mike
Installing a tuner will pooch the warranty, if they know about it. I myself use nightrider.com XIEDS ( $125) on my 09 FLHTC with high flow air cleaner and tuned Supertrapps. ( my headers have no catalytic convertor). The xieds plug inline with the o2 sensors, and are quickly removed for that dealership visit for a recall or other service. I have very good result, and I leave my motors at stage 1 so it should be all I need. MPG is 43 at 70 MPH cruising ( check some of the mpg complaints from tuner users)
Mike
Mike
