Rear wheel on Street Glide
RE: Rear wheel on Street Glide
ORIGINAL: Bryan TTM
150 Metz....you can get a 160 on if you trim the belt gaurd...rumor has it that its ill handling compared to the 150, aint tryed one to see
I'd think the bagger would actually turn better having a more rounded radius on the back. Like a 160-180. If you look at our baggers now the wierd tire they got on there goes pretty much from flat to edge within an inch or two. Not great for carving but obviously it works. The 160 on my wifes street bob is huge in comparison to my bagger. And that thing handles great. Wish I could get a real 160 or 180 on my bagger without paying through the nose for it. I hate having to buy a new fender, paint etc etc. I'll probably squeeze a Metz 160 on it at the next tire change.
lp
[IMG]local://upfiles/7297/238572AC8BD54562AC493C70E29ACF7A.jpg[/IMG]
lp
I've talked to several people and they all said that the 160/70-18 handled poorly on the 3 and 3.5 wheels. CFR says that they are running a 5.5 wheel with a 160 tire and it handles well though. If that's true, thats likely because the narrower wheel is causing the tire to be too rounded. If you check the Metzeler web site the recommended wheel range for a 160/70-18 is 4.25-5.00. Now as for the handling of a 160/80-16, I've nottalked to anyone on those. but the recommended wheel range is 3.5-4.5.
kinda what i figured, too small a rim...the 07's will accept a 4.25" rear rim tho
ORIGINAL: tsglide
The handling problems occur because of the load rating on the tire not being sufficient for the baggers.You need at least a 76 load rating IMHO.
Otisroundtree
03-06-2006 02:24 PM
