dyna beads question
Old 03-18-2012, 12:48 AM
menace929's Avatar
menace929
menace929 is offline
Originally Posted by BIGVTWIN
I can't get them thru the valve stem. And yes I removed the core from the valve stem.
Any ideas?
Easiest way is to hold an engraver tool against the valve stem. The vibration helps them flow through.
Old 03-18-2012, 05:27 AM
Just Dave's Avatar
Just Dave
Just Dave is offline
Originally Posted by BadBagger08
Their Snake Oil take the tire to be balanced and you will see.
I went through a similar issue tried up to 4oz of dyna beads and my front tire still vibrated terribly at any seed around 85
my indy threw away the dyna beads and balanced the tire and all is good he checked the balance of the beads and they did nothing in my case to help.
From the FAQ on here http://www.innovativebalancing.com/news.htm
Can I put the tire on a balancer to see if it's working?
A: No. Dyna Beads operates on physics principles, and requires the tire assembly to be in motion against a road surface to detect the exact counterbalance position. An electronic balancer has a solid, fixed mount, and does not allow the tire to react to imbalance.
I have been using them for years and love them, Not a wheel weight 1 around my house . Only had trouble 1 time and the tire was bad. Bent wheels can cause problems as well.
Old 03-18-2012, 09:33 PM
murph's Avatar
murph
murph is offline
I used the beads on my last bike. Not a problem. matter of fact, it worked better then with lead weights.
Old 03-18-2012, 10:02 PM
gwphelpss10's Avatar
gwphelpss10
gwphelpss10 is offline
Save yourself some money and go to Walmart and buy some airsoft pellets. They are plastic and won't hurt the tire. I bought the 12 gram pellets it takes 250 to make 1oz. been using them and they work great. 5000 airsoft pellets cost around $10.00. Just put them in the tire before you set the bead and all is good.
Old 03-19-2012, 01:21 AM
mike5511's Avatar
mike5511
mike5511 is offline
I just thumped the valve stem with a screwdriver as I poured mine in...worked just fine.
Old 03-19-2012, 07:16 AM
JohnFlorida's Avatar
JohnFlorida
JohnFlorida is offline
[QUOTE=BIGVTWIN;9538411]I can't get them thru the valve stem. And yes I removed the core from the valve stem.
Any ideas?[/QUOTE
Sometimes you need to run a 1/8 drill thru the stem to clear it first. I had to with my tube tires
Old 03-19-2012, 08:19 AM
Spur56's Avatar
Spur56
Spur56 is offline
I have used dyna beads in many applications and they are great. Using another product in a recent tire change on the UC called Ride On. It offers the same dynamic balancing as the beads, but additionally it will seal certain punctures. It is a water soluble liquid that will not corrode metal. So far it is working great with the balancing, hope I don't have to test the puncture feature. Be safe out there! Still have beads in my other bikes.
Old 03-19-2012, 08:46 AM
Just Dave's Avatar
Just Dave
Any ideas?
I use a pipe cleaner and run it through the stem several times. I have never had to do anything other than just tap the stem with my finger to get them in after using the pipe cleaner.
Old 03-19-2012, 10:05 AM
CHOPPIN' CHARLIE's Avatar
CHOPPIN' CHARLIE
CHOPPIN' CHARLIE is offline
Cool
Unable to get beads in. Finally thought to get the tire off the floor and beads flowed in as advertised. I like 'em. Several friends got 'em & all like the beads.
Old 03-19-2012, 10:06 AM
Keithhu's Avatar
Keithhu
Keithhu is online now
Received 5,609 Likes on 2,727 Posts
Here's the other question - how do you get the weights without marring the wheels?
Quick Reply: dyna beads question
