tubed Tire Repair Kit Recommendation
Old 03-17-2012 | 08:26 PM
piasspj's Avatar
piasspj
Repairing a tubed tire along side the road is a PITA. The process is the same as on a bicycle but with larger spoons. Same patches will work.
It can be done without removing the wheel from the bike (try it on your bicycle) it isn't easy.
Laying the bike on it's side is a lot easier than trying to do it with the bike standing. It also makes it possible to remove the wheel if you have to.
Old 03-19-2012 | 08:24 PM
cobby's Avatar
cobby
This is worth a look.
http://ride-onshop.com
Old 03-19-2012 | 08:42 PM
DTTJGlide's Avatar
DTTJGlide
It depends on how much you ride & how bullet proof you want to be, I had 150K on spoke rims without a flat. I did say had, I got 2 flats within 2 weeks last year, the first one I used my towing ins & was able to borrow a car to get a spare wheel & tire I had at home. That wasn't too bad since that tire was almost worn out, happened again about 10 days later & that time it ate up a brand new tire, I now have mags on my bike. There are a couple of places that can seal spoke rims, supposedly for life, but it isn't cheap. I can't imagine trying to do a tube repair on the side of the road withonly tools that you can carry in your saddlebags.
Old 03-19-2012 | 09:41 PM
Gunslingertom's Avatar
Gunslingertom
Flats scare the crap outta me.
When I was a kid, me and my girl were riding a full dressed 750 Hondamatic. Not a huge bike by any means, but darn big at 65 mph with a blowout. I tried like crazy to keep it up and couldn't. Didn't help that it blew just as I set the cruise and was taking my hands off the handlebars.
I went skidding down the asphalt on my side and my girl sorta rode on top of me. By the time I stopped, I had road rash from my ankle to my waist and from my wrist to my shoulder. My girlfriend had a little patch of it on her forearm.
We were very lucky. No helmets, but at least we were wearing long pants and not shorts like a lot of them wear. The bike was totaled.
If you're going to ride, it's just something you have to get over. For months after that, I could swear that the front end on my new bike wobbled, but it didn't.
No one ever figured out why that tire blew out. It was a new tire. But one thing I never did was worry much about them. I'd check tread depth when I was thinking about it and had them changed when they needed changed. I NEVER bothered to check air pressure, alignment, wheel runout, etc, etc. And all that will cause problems if out of spec. Afterward, I checked tires and wheels meticulously and have yet to have another blowout. I'm still **** about it.
Not a single word of my post will help with your question about tube repairs. I guess I just relay my story so you all will take them tires seriously. It's life or death.
Old 03-20-2012 | 10:34 AM
carlgrover's Avatar
carlgrover
I blew out the rear on my Road Couch a couple of weeks ago. I was within 1 or 2 miles of the house so I just limped it home. Road in second gear as slow as I could go. That was one squishy ride. Hard to keep it on the road. I pulled over and checked when I first realized something was wrong. The tire was still fully on the rim, otherwise I wouldn't have tried riding with a flat. Still not too smart but stupid is as stupid does. I don't think I damaged the rim since the new tire rides smooth. I wouldn't want to go very far like that.
As far as recommendations for a repair kit go, your best bet is probably towing insurance. I change my own tires and even with a tire changing fixture, it ain't a whole lot of fun. Lots of extra tools required including a way to reinflate the tire.
Old 03-20-2012 | 10:39 AM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
Originally Posted by Rockrivr1
So I did a search for tire repair and there is a slew on fixing a tubeless tire, but couldn't find much on fixing a tubed tired. I have an 06 RKC, which I believe has tubed tires. From my searching I'm going to get a Slime Compressor and need to find a kit that will help me fix a flat on a tubed tire.
This might be lame to say on a motorcycle forum, but I road ride on a bicycle thousands of mile a year for charity and use a spoon and patching kit to fix flats for that bike. It's a PITA on a bicycle, so I have to imagine it's the same on a motorcycle. But I'd rather have a kit then not.
So any recommendations on what kit works best will be appreciated. Thanks for the help.
Since you have the Slime compressor..... just buy the Slime sealant for tubed motorcycle tires. http://www.slime.com/shop/tire-sealant/
That will get you to a shop to have a new tube put in.
Last edited by shooter5074; 03-20-2012 at 10:42 AM. Reason: Porn makes my wiener feel funny
Old 03-20-2012 | 11:00 AM
DTTJGlide's Avatar
DTTJGlide
I don't see anywhere that it can be used in a tubed tire, near the bottom it says "can be used in a tubeless motorcycle tire".
Old 03-20-2012 | 11:03 AM
shooter5074
I used it on my wife's Dyna once, and it got her 80 miles to a shop for a tube replacement.
http://www.slime.com/shop/tube-sealant/
Old 03-20-2012 | 11:21 AM
DTTJGlide's Avatar
DTTJGlide
That's a different link. I'm glad it worked for you & your wife, it might work some of the time, but since a tube often rips after being punctured it won't work every time. It would still be good to carry, you might get lucky, I would ride very cautiously till it was replaced.
Old 03-20-2012 | 11:54 AM
Nirvana's Avatar
Nirvana
On a bagger, you might be able to get the right angle to insert it in the front tire, but the rear tire, you'd be SOL.
e6fmf
03-29-2016 09:11 AM
Dynamite17
2014-2023 Touring Models
22
01-30-2016 07:35 PM
Tek74
02-17-2011 03:05 PM
Tactical111
EVO
10-19-2010 08:51 AM
carpetride
04-22-2008 11:00 AM
Quick Reply: tubed Tire Repair Kit Recommendation
