One of my bulbs burnt out, and I am wondering if there is a replacement that I can purchase at an auto parts store, rather then the dealer. Also, maybe a better or brighter alternative.
Probably going to replace both, if one went the other is not too far behind.
I would imagine an auto parts would have it. Just take it in and have the counterman cross ref it if needed. I just replaced one of my front turn/running lamps yesterday. I had what I believe was a standard 1157 bulb taillamp/brake lamp and it mounts proper and illuminated the same.
If your passing lamps have the removeable bulbs, try Autozone....various wattages for around $8 ea. I'm running the brighter ones, somewhere around 50/55w ea. No problems. As I recall they are the 8XX series.
I opened mine up, and I can remove the bulbs. I am going to go with the brighter ones, so I guess the 896 bulbs are what I will need. Off to the auto parts store I go.
As far as I can find, a STD bulb kicks out 350 lm (lumen). I find mine own STD lights disappointingly yellow. An 886 might kick out 1255 lm but draws a lot more power which city riders will find drains their battery.
