-=-= HD Independent Control Auxiliary Lamp Wiring Harness 69200441 -=-=
I installed my HD 69200441 Harness over the weekend. In case your not familiar with this HD Harness, it will allow your Driving Lamps to stay on when you have your Hi Beams on. Once thing I noticed now, when my ignition switch is in the Accessory position, my Driving Lights come on unless the switch is turned off. I know it didn't do that before, and just wondered if that was normal after the Harness installation?
I also installed my 71764-07 Momentary Switch that I soldered and hooked up to my Garage Door Opener. Here are a few pics of that !!
Thanks
Dom
Thanks
Dom
I also put the Auxiliary Lamp Wiring Harness on last weekend the instructions say that the it plugs in to the harness under the fairing on the right fairing mount, nope, it was under the rocker switch cover on the right side, and you are right with the spot light switch on they do come on in the Acc position, didn't notice it till you said something..
Thanks, normal then I guess. Yes, it was right there when I pulled the rocker switch console off to put the 71764-07 switch in for my garage door opener. I never even pulled my fairing off. I'm glad I did the switch install first, or I would have thought I would have to pull the Fairing to do the Harness. Did them both in 25 minutes, and I was distracted by two Nipples too
luckyfdr
03-19-2013 06:51 AM
69200441, added, auxiliary, control, harley, harness, independant, independent, installation, kit, lamp, light, softail, ultra, wire
