Help with which splice to install ignition disable...
I've got 5 choices as described in the instructions for splicing in the ignition disable of my Scorpio Alarm. I will list them and I am looking for suggestions on which would be the most logical and exactly where do I locate the wire (and color?).
Options:
1) Positive lead wire or ground wire on fuel pump
2) Positive lead wire on fuel injection system (note: I have a TFI installed)
3) Positive wire that goes to the ignition fuse in fuse box.
4) Ground wire from ignition module
5) Positive wire from ignition module to the ignition coil
Maybe not necessary: pics are above and beyond but would be much appreciated.
Thanks
Options:
Thanks
Splice in to ignition wire
Options:
Thanks
Options:
Thanks
Did you ever find which wire to splice in to for the ignition disable on the scorpio alarm? I'm about to do the same for my scorpio install. I know which is the fuel pump based on the connector but was wondering if its better to tap the disable in to the actual ignition wire. From looking through the wire diagram it appears to be an solid gray wire, but not 100% sure and don't want to cut only to have to fix it if its the wrong wire. Any help is appreciated.
Bump.....let's hear it peep's I for one and interested. When I used to watch Son's of Anarchy and see Jacks shut his bike off with a switch above the rear passenger peg I used to think, " That would be handy". If you end up doing it, try to post pics and a DIY tutorial for those like myself.
Me personally I'd use option #3. That wire is grey coming out of the fuse box off the ignition fuse. Obviously this wire is crucial to your bike starting so I'd also opt to not do anything other than solder and heat shrink it.
Option #1 is not bad either. That wire color is orange/grey in color coming off the fuse box fuel pump fuse as well. My issue with this is the bike will still start but will die shortly afterwards since the fuel pump is not active.
Options:
Thanks
Options:
Thanks
Thanks ultranutz, I ended up going with the orange/gray wire going to the power of the fuel pump. I figured this way if something with the scorpio module or wiring went wrong the bike would start to sputter off and hopefully give me time to react and get out of danger, at least that's the justification I made for going that route.
Also instead of cutting the main wiring harness wire that is under the tank, which I contemplated, I sliced open the black cover that goes around the fuel pump wires which is attached to the center console that sits on top of the tank and spliced in to the orange/gray cable there. That fuel pump harness is an easy replaceable piece, so if I messed up bad I could replace the harness cheap and easy. Further, if I ever sell the bike I can remove the scorpio alarm and just replace that harness, allowing me to transfer the alarm to new bike. Splicing in to main harness wires under the tank is a lot less forgiving and not flexible.
Sorry tucci but I didn't take any pictures. The work was actually very easy, just need to remove the seat, unplug the fuel pump harness which is on left if facing the the dash, cut open the black cover that wraps the fuel pump cables, cut the orange/gray cable and splice in the scorpio anti hijack wires, then tape it all back up nice and tight for protection.
It took me longer to work up the courage to cut in to the wires than to actually do the work.
jacknthebox
03-16-2012 06:04 PM
