noticed a issue, am i the only one?
i have my bike on the jack putting all my front end components on and i walked behind the bike and noticed my exhaust tips are not sticking out under the bags the same. they are 3/4'' difference the clutch side of the bike is shorter than the brake side of the bike. i dont think anyone will ever notice it but its killing me, im wondering if they are all like that or is it just my bike. i have stock head pipe and 4'' rush slip ons. this is 2011 flhx im thinking its time to pull out some tools and cut and weld it all back like it should be
Maybe the slipons are on each pipe a different depth? I check this whenever I install my mufflers. You should be able to adjust this by loosening the muffler clamps and mounting bolts under the bags. I center mine by making sure the hanger under the bags is centered between the two brackets on each muffler, if that makes sense.
Pull the bags and look at where the rear hanger is in the rubber mount. Odds are pretty good ya just need to loosen the clamp and slide the slip on, on a little further. Retighten of course, but might just do it. No welds needed and if you need to cut, do it in small increments, guess how i know.....![Icon Teeth](https://www.hdforums.com/forum/images/smilies/icon_teeth.gif)
Kris
Kris
