I Need some help, running like crap after fuel filter change
I changed my fuel filter today. The kit came with a new corrugated hose, so I changed that too. I idles fine, but when you give it throttle, it spits and pops.
What could I have done wrong. It's running like it's starving for fuel. I am going to have to drain the tank, and pull it apart again. What should I be looking for in there?
Will I need to buy yet another set of bolts with the seals on em? How about the new rubber gasket that I just put on?
Thanks in advance for the help.
Since it was working before,sounds like something bad with the install.
I know that hose is hard to remove and install.I would check for cracks on the hose ends of the regulator.Check electrical connections.
There is no need to drain the fuel.Just work on it in a safe place,like away from water heater.
I think i would reuse the new screws and gasket,just check for leaks.
I took it back apart, checked thes hoses, electrical connections, etc, I fired her up and it seems to be running good now. I wont be sure until I get it out on the road for a test ride. Maybe one of the hoses was kinked in there. Hopefully that all it was.
OK, so It's still running very poorly. I disassembled again, bought another convoluted hose (the one that goes from the fuel pump to the filter), buttoned up, and still the same problem.
So I completely drained the tank, un bolted the the other convoluted tube, put air pressure to it while in a bucket of water, and no bubbles, no hole.
I'm at my whits end here, what the h*ll did I screw up? I have been using the HD hose clamps, but I do not have the crimping tool. I used channel locks to crimp them and tighten them up. Could this be my problem?
Can I just use regular hose clamps?
Please help, not sure what to do next.
Maybe the o-ring got messed up when installing the new filter? I'd pull it all out and check the regulator as well. You also might want to check the fitting under the tank and where it connects inside the tank. Did you have a problem bending the arm to get it back in or did you finagle with it for a while?
